Hi, I am trying to setup an OpenVPN Server on my Asus RT-AX56U running Asuswrt-Merlin 388.2_2. I have setup the server and can connect from my client, however I am unable to access any devices on the LAN. This includes the router itself, I can not ping 192.168.1.1 nor can I navigate to the web GUI at that address.
I have trawled through dozens of forum posts both here and elsewhere, and attempted almost every proposed fix that I could find, with no luck. Weirdly, I had the server up and running without issue on the stock Asus firmware, however since moving to Merlin this issue has persisted. Below is a photo of my OpenVPN configuration (with the server port removed, but it is configured usually):
I've seen similar issues where the user was able to access the router itself once connected to the VPN but no LAN devices behind that, in my case I'm unable to ping or otherwise access anything including the router.
To save everyone some time and effort, here is a list of things I have attempted in order to resolve the issue. All of the attempted resolutions below have since been reverted so if the proposed solution is one of the following PLUS something else, please let me know so that I can reconfigure correctly
- Changed the "Client will use VPN to access" setting from "Lan Only" to "Both"
- Set "Manage Client-Specific Options" to "No"
- Disabled static routes
- Added
to my OpenVPN custom configCode:
push "route 192.168.1.0 255.255.255.0" - Disabled AIProtection
- Disabled router's firewall entirely
- Enabled ping router from WAN
- Enabled "Advertise DNS to Clients"
