Asus RT-AC5300 PPOE relay problem
่่Jiero
Hi Can someone help to see log file , I have problem internet unstable more than 4 day and my ISP confirm their link is normal , I found link unstable on today 20 April 12.05 PM as in log file but in log show 5 May and Found error as below , After that 12.35 PM it turn back to normal but I'm reboot router , I found this error for 4Day please help to solve this problem , Because I already contact Asus and they response me very slow (In Picture N0.1 when I can't use internet I try Trace to 8.8.8.8 ) (In Picture No.2 Internet is back to normal I trace to 8.8.8.8)
May 5 12:05:09 RT-AC5300: start https:8443
May 5 12:05:09 RT-AC5300: start httpd:80
May 5 12:05:10 kernel: JFFS2 notice: (188) check_node_data: wrong data CRC in data node at 0x02618cd8: read 0xaffe4d7a, calculated 0x5de574f6.
May 5 12:05:10 NAT Tunnel: AAE Service is stopped
May 5 12:05:10 AAE: AAE Service is started
May 5 12:05:10 disk monitor: be idle
May 5 12:05:10 jffs2: valid logs(1)
May 5 12:05:10 hour monitor: daemon is starting
May 5 12:05:10 ERP: The model isn't under EU SKU!
May 5 12:05:10 miniupnpd[366]: version 1.9 started
May 5 12:05:10 miniupnpd[366]: HTTP listening on port 33566
May 5 12:05:10 miniupnpd[366]: Listening for NAT-PMP/PCP traffic on port 5351
May 5 12:05:11 avahi-daemon[360]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
May 5 12:05:11 lldpd[370]: minimal kernel version required is 2.6.39, got 2.6.36.4brcmarm
May 5 12:05:11 lldpd[370]: lldpd may be unable to detect bonds and bridges correctly
May 5 12:05:11 lldpd[370]: consider recompiling with --enable-oldies option
May 5 12:05:11 lldpd[378]: cannot get ethtool link information with GLINKSETTINGS (requires 4.9+): Operation not permitted
May 5 12:05:11 lldpd[378]: cannot get ethtool link information with GSET (requires 2.6.19+): Operation not permitted
May 5 12:05:11 avahi-daemon[360]: Alias name "RT-AC5300" successfully established.
May 5 12:05:12 WAN Connection: Fail to connect with some issues.
May 5 12:05:15 Mastiff: init
May 5 12:05:15 syslog: module ax88179_178a not found in modules.dep
May 5 12:05:15 wan: [wan0_hwaddr] == [34:97:F6:6B:EB:F0]
May 5 12:05:15 pppd[447]: pppd 2.4.7 started by admin, uid 0
May 5 12:05:16 pppoe-relay[442]: PADO packet from 28:a6:db:62:98:2f on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppoe-relay[442]: PADS packet from 28:a6:db:62:98:2f on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppd[447]: Connected to 28:a6:db:62:98:2f via interface eth0
May 5 12:05:16 pppd[447]: Connect: ppp0 <--> eth0
May 5 12:05:16 pppoe-relay[442]: PADO packet from 0c:45:ba:20:5e:82 on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppoe-relay[442]: PADO packet from dc:99:14:14:44:92 on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppoe-relay[442]: PADO packet from 28:a6:db:62:98:3f on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppd[447]: PAP authentication succeeded
May 5 12:05:16 pppd[447]: peer from calling number 28:A6:DB:62:98:2F authorized
May 5 12:05:16 pppoe-relay[442]: PADO packet from 0c:45:ba:24:8d:4f on interface eth0 does not have Relay-Session-Id tag
May 5 12:05:16 pppd[447]: local IP address 124.122.255.88
May 5 12:05:16 pppd[447]: remote IP address 124.122.254.1
May 5 12:05:16 pppd[447]: primary DNS address 203.144.207.29
May 5 12:05:16 pppd[447]: secondary DNS address 203.144.207.49
May 5 12:05:16 rc_service: ip-up 462:notify_rc start_firewall
May 5 12:05:17 wan: finish adding multi routes
May 5 12:05:17 rc_service: ip-up 462:notify_rc stop_upnp
May 5 12:05:17 rc_service: waitting "start_firewall" via ip-up ...
May 5 12:05:19 WAN Connection: WAN was restored.
May 5 12:05:19 WLCEVENTD: eth2: Assoc CC:78:5F:01:C9:64
May 5 12:05:20 ntp: start NTP update
  • syslog (6).txt
    syslog (6).txt
What firmware are you running? What features are you using?
When was the last time you did a full reset to factory defaults after flashing the latest firmware and then manually and minimally configuring the router to secure it and connect to your ISP?
If you turn off your router and your modem/ONT for at least 20 minutes, then turn on the modem/ONT and wait for 5 minutes, and then turn on your router, is the issue fixed?
If the above doesn't solve the issue and if you haven't performed a full reset to factory defaults recently, please see the link in my signature to the M&M Config set up to get your router to a good/known state once again.
Now My firmware is 3.0.0.4.384_45149
I never full reset to factory after upgrade firmware
I will try to do this solution , Thank a lot
If it doesn't work I will try the M&M Config , thank you so much for your help
You're welcome and hope the easier option works for you, for now. :)
There has been a lot of good changes to the latest firmware for most Asus routers, yours isn't released yet, but be sure to keep checking and I'm sure it will be released soon enough.
It will probably be the RT-AC5300 (not GT!) 3.0.0.4.384_45713 firmware version when it is released. ;)
I Forgot 1 Question
My feature is wireless router , I Request ISP config their router to Bridge mode and connect to RT-AC5300 use PPOE , I use this feature for many month but this problem just happend around 4 day
I Forgot 1 Question
The 'power off, wait, then power up the modem/ONT and then the router' dance may sync you up to your ISP properly again. If you can wait for longer than 20 minutes (a full hour should be enough), it may be better with your particular ISP. ;)
I will try power off for full hour. Thank again
