Speedy1205
Hi Guys,
maybe someone has a good Idea about this "issue". The Asus Router is at the moment mi first Router as the 3G Modem works with it. I have the the wireless enabled and 2.5 and 5GHz working fine and with my intel card I can transfer around 30 MB/s to a share.
The Netgear I have setup as Access Point and connected the WAN port to one of the LAN ports to the Asus Router. Performance is a bit better as I can get 35 MB/s but that's not the problem
When I connected to the Asus wireless than the page (www) loading sometimes very long, very long. But when I open them with the WiFi connection with the Netgear they get open immediately.
Its sometimes really annoying those Loading times, but I would like to fix this a kind of. Someone has any Ideas ? Just keep in mine the internet connection is connected to the asus and both routers using the same.
Maybe its just about the Hardware what makes the differences as the R7500 has a very powerful processor ?
(378.51_dpi)
Thanks for advice's
@GATEWAY:/tmp/home/root# uptime
15:17:52 up 1 day, 7:30, load average: 0.39, 0.11, 0.07
(378.51_dpi)
Thanks for advice's
