Asus RT-AC66U with openvpn client and pptp server at the same time
ramraid
Hi
I have an Asus RT-AC66U with an openvpn client connected to HMA.
I am running Merlins great AsusWRT firmware version 3.0.0.4.376.47_0
I have managed to setup a custom script (wan-start) to exclude certain ports and hosts that i don't want to go via the VPN and that is working a treat. I also managed to get my plex server visible from the outside would with the same script
Last thing i would like to do is be able to have a pptp vpn server running at the same time so that i can access my home network for the outside world. However i can't access my wan ip while the vpn client is running to connect remotely
Once i get the pptp server working then maybe i will change to an openvpn server, but one step at a time.
I can connect to the PPTP vpn server and login from my LAN (using the wan IP) but not from the WAN
Can anyone help?
Cheers in advance
Hi
Can anyone help?
Cheers in advance
I don't recommend PPTP servers. they are old and not secure. Use OpenVPN server instead
