Release ASUS RT-AC68U Firmware version 3.0.0.4.386.46065
Objects in Space
Version 3.0.0.4.386.46065
2022/01/27
92.84 MBytes
Security
- Fixed string format stacks vulnerability
- Fixed cross-site-scripting vulnerability
- Fixed informational vulnerability.
Thanks to Howard McGreehan.
-Fixed SQL injection vulnerability
-Fixed json file traversal vulnerability
-Fixed plc/port file traversal vulnerability
-Fixed stack overflow vulnerability
Thanks to HP of Cyber Kunlun Lab
-Fixed authenticated stored XSS vulnerability
Thanks to Luke Walker – SmartDCC
-Fixed LPD denial of service vulnerability
-Fixed cfgserver heap overflow vulnerability
-Fixed cfgserver denial of service vulnerability
Thanks to TianHe from BeFun Cyber Security Lab.
Added more ISP profile
Digi 1 - TM
Digi 2 - TIME
Digi 3 - Digi
Digi 4 - CTS
Digi 5 - ALLO
Digi 6 - SACOFA
Maxis - CTS
Maxis - SACOFA
Maxis - TNB/ALLO
Fixed AiMesh guest network issues.
Fixed DDNS issues where the WAN IP is IPv6
Fixed UI bugs in Administration --> feedback.
Fixed time zone error.
Please unzip the firmware file first then check the MD5 code.
MD5:33b491c21c167a8beec2f450aafe1bc2
That was quick... the last AC68U release was just a month ago.
OE
Flawless "online" upgrade for both my RT-AC68U (Router) and RT-AC1900U (Media Bridge).
With a quick look through the configuration pages I didn't encounter any differences, no lost settings.
Does the problem of being unable to uncheck disable 11b if you enable this setting still occur in this firmware release?
Noticed that the MD5 for both the RT-AC68U and the RT-AC66U-B1 is the same. Some have said before that the 66U-B1 is just a 68U with a faster processor.
My TP-Link Bulbs and plugs appear offline to alexa and Tapo app when I enable DoT in WAN section. Disable it and apply they are back online. It's consistent but doesn't happen with Merlin DoT.
Be my guest to try ;)
Yup, the firmwares are interchangeable. Merlin has one version for the AC68U and AC66U_B1.
It's the exact same firmware image for these two models.
Well I have tried Guest 1 with the Tapo devices, still appear offline. Sent feedback to Asus see if they can fix it. As I say dont happen on Merlin DOT.
Working well so far. The following bug was FIXED:
DDNS - Dynamic DNS
Router no longer displays an error: "Request error! Please try again."
AC86U is in dead last again.
Seems like this model has troubles from the start. The first HND platform Asus router.
46065 works properly on AC1900P, as expected. My favorite Asus router and test platform. It just works with everything.
