Oscarracso
Hi Everyone,
I have the rt-ac68u and from one day to the next the 2.4ghz wifi signal stopped working. It just doesnt broadcast nor can i connect to it manually. This happend after i pressed the reset button for like 10/15 seconds. I did this because i wanted a clean router and start over. The 2.4ghz signal allways worked fine.
Things i have tried;
Flash the newest firmware from Asus
Reset
Pressed wps button while switching on to make sure everything is clean.
No joy.
Flashed newest dd-wrt. Same process as above, no joy.
Flashed the newest merlin. Same process as above, no joy.
Flashed latest tomato. Later i read there's still no full support for the router so i went back to asus firmware.
Flashed old firmwares from asus or dd-wrt.
No joy.
Currently the router is at the latest beta from merlin. (may 2018)
Later i realised i still have an old config lying around from another ac68u wich was configured as an access point. So at the first screen of the asus router i uploaded the config. This process took like one hour. This all goes via a lan port. tried different kinds of cables, differtent laptops even, same story. Nevertheless, the config was uploaded succesfully.
What i noticed was this; still no 2.4ghz signal. But; when i erase the router,so to default, and i ping it (192.168.1.1) i get high latency, sometimes 2344ms, sometimes 2 times 1ms, no reply etc. When i put the config back in it, (yep, wait another hr) the ping times are all a decent 1ms.
I remember i once telnetted into the router and did an erase of a nvram partition. If you ask me it has something to do with this part, sometimes the router also doesnt save the settings after an initial setup process.
So if aynone has any suggestions besides throwing the ac68u out the window..
Reset
No joy.
No joy.
