Hi guys,
Hopefully someone can help here. I got an RT-AC68U about 2 weeks ago. I connected it to my Thomson DG587 v3 which I put in to bridge mode. I have just set up the Asus router by following the quick set up, no other changes.
Ever since I got this router, certain apps on a few of my Android devices won't update/load/refresh when I'm on wifi. For example, if I open Instagram, the main feed loads, but the notifications won't load, it just spins trying to load forever. Another example is Flipboard, when I open the app it doesn't update any of the content, again this happens on wifi only. I also use a podcast app called pocket casts which does the same thing, when I open it it tries to refresh and look for new episodes but just hangs.
This is happening on 2 phones and my Nexus 7, all of which worked fine before I got this router and in the case of the phones, if I turn off wifi everything works fine.
I have tried all devices on other wifi networks since the issue started happening and they all work fine, so it seems isolated to my wifi network.
To further complicate things, if I close any of the affected apps, then clear them out of the recently opened apps using the app switcher button (so removing them from the device cache) most of the time they will work properly the next time I open them, but then every subsequent time I open them the issue comes back.
Also, sometimes just hitting the refresh button in the affected apps can cause them to work.
Really weird issue and has me stumped, hopefully someone might have some insight??
