Asus RT-AC86U
sufianabrar
I am building firmware for RT-AC86U from source code asuswrt-merlin.382 in my linux viertual machine Ubuntu 16.04.1 but there are few errors.
root@ubuntu:~/asuswrt-merlin.382/release/src-rt-5.02hnd# make rt-ac86u
CONFIGURED MODEL: RT-AC86U
SPECIFIED MODEL: RT-AC86U
Clean old model configuration
Update model configuration
make bin
make[1]: Entering directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
BRCM_BOARD_ID=94906REF
# prepare config_base
# prepare prebuilt kernel binary
do nothing
hnd_router platform work
make[2]: Entering directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
Using profile, build config.
CURRENT_ARCH=aarch64 TOOLCHAIN_TOP= make prek
make[3]: Entering directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; echo -e "\n# Automatically generated file -- do not modify manually\n\n" > Kconfig.autogen.tmp
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; echo -e "\n# Automatically generated file -- do not modify manually\n\n" > Makefile.autogen.tmp
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; echo -e "\n\$(info READING AG MAKEFILE)\n\n" >> Makefile.autogen.tmp
alldrivers=""; \
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; \
for autodetect in $(find * -type f -name autodetect); do \
dir=${autodetect%/*}; \
driver=$(grep -i "^DRIVER\|FEATURE:" $autodetect | awk -F ': *' '{ print $2 }'); \
[ $driver ] || driver=${dir##*/}; \
[ $(echo $driver | wc -w) -ne 1 ] && echo "Error parsing $autodetect" >2 && exit 1; \
echo "Processing $driver ($dir)"; \
DRIVER=$(echo "${driver}" | tr '[:lower:]' '[:upper:]'); \
echo "\$(eval \$(call LN_RULE_AG, CONFIG_BCM_${DRIVER}, $dir, \$(LN_NAME)))" >> Makefile.autogen.tmp; \
if [ -e $dir/Kconfig.autodetect ]; then \
echo "menu \"${DRIVER}\"" >> Kconfig.autogen.tmp;\
echo "source \"../../bcmdrivers/$dir/Kconfig.autodetect\"" >> Kconfig.autogen.tmp; \
echo "endmenu " >> Kconfig.autogen.tmp; \
echo "" >> Kconfig.autogen.tmp;\
fi; \
true; \
done; \
duplicates=$(echo $alldrivers | tr " " "\n" | sort | uniq -d | tr "\n" " "); echo $duplicates; \
[ ] && echo "alldrivers: $alldrivers" && echo "duplicates: $duplicates" || true; \
if [ $duplicates ]; then \
echo "ERROR: duplicate drivers found in autodetect -- $duplicates" >&2; \
exit 1; \
fi
Processing SPU (opensource/char/spudd)
Processing MCAST (opensource/char/mcast)
Processing PDC (opensource/char/pdc)
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; [ -e Makefile.autogen ] && cmp -s Makefile.autogen Makefile.autogen.tmp || mv Makefile.autogen.tmp Makefile.autogen
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers;[ -e Kconfig.autogen ] && cmp -s Kconfig.autogen Kconfig.autogen.tmp || mv Kconfig.autogen.tmp Kconfig.autogen
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/bcmdrivers; rm -f Makefile.autogen.tmp Kconfig.autogen.tmp
ln -s -f /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/include/uapi /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/bcm_local_kernel_include;
ln -s -f /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/arch/mips/include/uapi /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/bcm_local_kernel_mips_include;
ln -s -f /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/arch/arm/include/uapi /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/bcm_local_kernel_arm_include;
echo
echo -------------------------------------------
echo ... starting kernel build at /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1
echo ARCH=arm64
ARCH=arm64
echo KERNEL_ARCH=aarch64
KERNEL_ARCH=aarch64
echo BCM_SWVERSION_FILE=/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/include/linux/bcm_swversion.h
echo BCM_KF_KCONFIG_FILE=/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/Kconfig.bcm_kf
echo PROFILE_KERNEL_VER is LINUX_4_1_0
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel; \
if [ ! -e /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/.untar_complete ]; then \
echo "Untarring original Linux kernel source: src-linux-4.1.tar.bz2"; \
(tar xkfpj src-linux-4.1.tar.bz2 2> /dev/null || true); \
touch /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/.untar_complete; \
fi
#/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/hostTools/scripts/gendefconfig /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/targets/94908HND/94908HND w
cd /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1; \
#cp -f /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/arch/arm64/defconfig /home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1/.config;
make oldnoconfig;
make[4]: Entering directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1'
make[5]: '../../.config' is up to date.
scripts/kconfig/conf --olddefconfig Kconfig
../../bcmdrivers/Kconfig.autogen:2: syntax error
Kconfig.bcm:1336: missing end statement for this entry
Kconfig:15: missing end statement for this entry
../../bcmdrivers/Kconfig.autogen:1: invalid statement
Kconfig.bcm:1338: unexpected end statement
Kconfig:20: unexpected end statement
scripts/kconfig/Makefile:84: recipe for target 'olddefconfig' failed
make[5]: *** [olddefconfig] Error 1
Makefile:565: recipe for target 'oldnoconfig' failed
make[4]: *** [oldnoconfig] Error 2
make[4]: Leaving directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/kernel/linux-4.1'
make.hndrt:332: recipe for target 'prek' failed
make[3]: *** [prek] Error 2
make[3]: Leaving directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
Makefile:4039: recipe for target 'setprofile' failed
make[2]: *** [setprofile] Error 2
make[2]: Leaving directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
Makefile:3873: recipe for target 'bin' failed
make[1]: *** [bin] Error 2
make[1]: Leaving directory '/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd'
Makefile:4022: recipe for target 'rt-ac86u' failed
make: *** [rt-ac86u] Error 2
I followed all your mentioned prerequisites steps but it does not work. Please help me in this case.
Broadcom's HND makefiles require bash. You have to symlink /bin/sh to point to /bin/bash.
Double check your shell configuration, your error is related to your Makefile not using bash but some other unsupported shell instead.
I followed all steps which are mentioned in asus.merlin.382 to build firmware of RT-AC86U in my virtual machine ubuntu 16.04 64-bit but nothing works. Do you have any more suggestions?
I don't, sorry. I use 16.04 myself, and the only thing that I had to change for the specific error message you posted was to ensure that /bin/sh pointed to bash, and that the default shell was bash.
lrwxrwxrwx 1 root root 9 Aug 27 02:16 /bin/sh -> /bin/bash
I reinstalled again ubuntu 16.04 and all the methods mentioned in asus.merlin.382, new toolchain .(https://github.com/RMerl/am-toolchains) and symlinked
ln -sf /bin/bash /bin/sh
And now I receive two different errors during finalizing in building the firmware.
uname: Linux ubuntu 4.8.0-36-generic #36~16.04.1-Ubuntu SMP Sun Feb 5 09:39:57 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
processors: 1
procs -----------memory---------- ---swap-- -----io---- -system-- ------cpu-----
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
 0  0      0   2568     56    664    0    0  1976   322  228 1329  9 11 57 23  0
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                1
On-line CPU(s) list:   0
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             1
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 94
Model name:            Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
Stepping:              3
CPU MHz:               2302.745
BogoMIPS:              4607.99
Hypervisor vendor:     VMware
Virtualization type:   full
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              6144K
NUMA node0 CPU(s):     0
Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts nopl xtopology tsc_reliable nonstop_tsc aperfmperf eagerfpu pni pclmulqdq ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch epb fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 invpcid rtm rdseed adx smap xsaveopt dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp
################ parallel build environment end ##################
shell is /bin/sh.  Bash version is 4.3.48(1)-release
ERROR: Attempting to build as root.
/home/sufian/asuswrt-merlin.382/release/src-rt-5.02hnd/make.common:2671: recipe for target 'prebuild_checks' failed
make[2]: *** [prebuild_checks] Error 1
The explanation is pretty plain to me in that error output:
Do not compile as root...
I have entered this command: chmod -R 777 asuswrt-merlin.382 and it resolved my issue.
Now I have generated ac86u custom firmware.
Thanks for your help.
