Asus RT-AC88U
Apharot
Hello all. I have an Asus RT-AC88U that seems to occasionally give me some fits. The firmware is upgraded to the latest stable. I keep seeing these 2 errors in the syslog whenever it goes through a fit of being unreachable (it isn't rebooting, just disconnecting all connections, being unavailable for a bit, and then allowing reconnects). The errors from the log are as follows:
May 19 10:52:11 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 10:55:18 syslog: WLCEVENTD wlceventd_proc_event(466): eth2: Deauth_ind 90:E1:7B:ED:83:0B, status: 0, reason: Disassociated due to inactivity (4)
May 19 10:55:18 syslog: WLCEVENTD wlceventd_proc_event(481): eth2: Disassoc 90:E1:7B:ED:83:0B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
May 19 10:55:19 syslog: WLCEVENTD wlceventd_proc_event(466): eth2: Deauth_ind 6C:E8:5C:0B:49:36, status: 0, reason: Disassociated due to inactivity (4)
May 19 10:55:19 syslog: WLCEVENTD wlceventd_proc_event(481): eth2: Disassoc 6C:E8:5C:0B:49:36, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
May 19 11:13:53 syslog: WLCEVENTD wlceventd_proc_event(500): eth2: Auth A0:6F:AA:16:0D:C7, status: Successful (0)
May 19 11:13:53 syslog: WLCEVENTD wlceventd_proc_event(529): eth2: Assoc A0:6F:AA:16:0D:C7, status: Successful (0)
May 19 11:21:05 syslog: WLCEVENTD wlceventd_proc_event(500): eth2: Auth 6C:E8:5C:0B:49:36, status: Successful (0)
May 19 11:21:05 syslog: WLCEVENTD wlceventd_proc_event(529): eth2: Assoc 6C:E8:5C:0B:49:36, status: Successful (0)
May 19 11:21:17 syslog: WLCEVENTD wlceventd_proc_event(500): eth2: Auth 90:E1:7B:ED:83:0B, status: Successful (0)
May 19 11:21:17 syslog: WLCEVENTD wlceventd_proc_event(529): eth2: Assoc 90:E1:7B:ED:83:0B, status: Successful (0)
May 19 11:21:18 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:19 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:22 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:23 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:24 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:25 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
May 19 11:21:26 acsd: There are still associated scbs, avoid channel switch(txfail_thresh)
Any help on this would be greatly appreciated. I did a google search, but did not find much on the SCBS error.
Thanks!
Bill
