Release Asus RT-AX86 Series Firmware version 3.0.0.4.388_24231 (11/07/2023)
iFrogMac
Its available now on the US site:
https://www.asus.com/us/networking-...s/rt-ax86u/helpdesk_bios/?model2Name=RT-AX86U
ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.388_24231
Version 3.0.0.4.388_24231
71.34 MB
2023/11/07
Bug Fixes and Enhancements:
- Fixed v6plus related Issues.
- Fixed ipv6 network service filter not work.
- Resolved an issue that caused hostname errors in the DDNS service.
- Resolved OpenVPN Server TAP Mode Issue.
- Fixed the problem that the AiCloud app cannot add router on Android 9.
- Ensured consistent display of client status on the WireGuard server.
- Enhanced system stability when accessing the WireGuard Server with DMZ enabled.
- Improved stability when enabling or disabling the WireGuard server.
- Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
- Corrected a bug encountered when adding a rule to the network services filter.
Security Fixes:
- Fixed several curl vulnerabilities.
- Fixed FFmpeg vulnerabilities.
- Corrected an OpenVPN vulnerability categorized as CWE-134.
- Strengthened protection against SSH brute force attacks.
- Fixed OpenSSL vulnerabilities.
Please unzip the firmware file, and then verify the checksum.
SHA256: f1a34160e7bb36d6867496020455ed084cd4c307a265cae77f22360166e1ccfb
Download:
https://dlcdnets.asus.com/pub/ASUS/...T_AX86U_AX86S_300438824231.zip?model=RT-AX86U
OK, installed the firmware on my RT-AX86U, so far no immediate problems. Also corrected my typing errors for the thread title, and date, so we should be good now.
the change log was copied directly from the info about the firmware in the UI, if there were any questions on that as well.
I checked again and it's now posted on the official site. Thanks for the heads up.
I wonder why this build is a 20000 changelog build but other devices getting 30000 changelog builds. Hmmm
Which "official site"? This new firmware isn't showing up yet (as of this post) at the following Asus links:
https://www.asus.com/networking-iot...s?model2Name=RT-AX86-Series-RT-AX86U-RT-AX86S
Assume it will be propagated to these links sometime in the next 24 to 48 hours.
Do not see this on the Canadian ASUS for sure. All I get is this May 2023 release :
Version 3.0.0.4.388.23285
70.86 MB
2023/05/15
S
- Release Note -
Security Fixes:
Thanks, but i think you need add the direct link.
updated through GUI, everything seems fine for me.
I copied and pasted the two links in the post above. When I went to the support site link from the router's UI, the new firmware wasn't listed yet. Hopefully this will cover it. This is my first time posting a firmware release thread.
71.34 MB
2023/11/07
Security Fixes:
Download:
