Asus RT-AX86s error that requires reboot everyday
calvin tran
Hello,
I bought it new in 2021 and it had been super reliable. I updated the firmware a couple months ago. Since then, the router lost the connections very often and many time I had to reboot to get it back.
Latest firmware: 3.0.0.4.388_23285-g5068da5
I was thinking of going back to the old firmware but I'd to hear from you first.
Thx
Here are some from the log
Oct 22 08:56:47 dnsmasq[1323]: failed to send packet: Resource temporarily unavailable
Oct 22 08:56:47 kernel: DROP IN=eth0 OUT= MAC=04:42:1a:cd:22:b0:7c:9a:54:a7:5e:f7:08:00 SRC=213.109.202.212 DST=10.0.0.185 LEN=44 TOS=0x00 PREC=0x00 TTL=224 ID=45929 PROTO=TCP SPT=51193 DPT=54333 SEQ=1163811548 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (02040218) MARK=0x8000000
Oct 22 08:56:48 dnsmasq[1323]: failed to send packet: Resource temporarily unavailable
Hello,
Thx
I'm not skilled at reading the log...
Do you know what connections you are referring to?
Given 2021 and trouble since last firmware update... have you tried recommissioning the router with same firmware, Reset that firmware, and configure it from scratch?
OE
all the devices (wired or wireless) in my house lost connection when it happened. I haven't tried the factory reset and reconfigure so I will try that.
You should know this first:
FW Reset FAQ
Reset button/webUI Restore/node removal - clears settings in NVRAM; reboot restores fw defaults from CFE
Hard Reset via WPS button/webUI Restore+Initialize - also clears data logged in /jffs partition
From the top:
o upload the firmware
o Hard Reset that firmware to its defaults (I use webUI Restore+Initialize )
o configure the firmware from scratch (do not restore from .cfg file)
OE
I did the reset and reconfigured my router from scratch. it's very simple: SSID for 2.4ghz and 5ghz, and transmit power level for each band.
So far so good.
