Asus RT-AX86U constant wifi drops
Fludbucket
Hello all,
Sorry that I am not very versed in reading router logs. I have an RT-AX86U, and it is constantly dropping internet. I tried installing merlin, factory resetting and any other tip I could find. Im hoping someone here can help me make sense of my logs and diagnose the problem.
Dec 14 20:01:11 wlceventd: wlceventd_proc_event(494): eth7: Deauth_ind 06:7B:B0:A9:62:AC, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Dec 14 20:01:11 hostapd: eth7: STA 06:7b:b0:a9:62:ac IEEE 802.11: disassociated
Dec 14 20:02:38 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xe832 (36/160)
Dec 14 20:02:38 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Dec 14 20:02:38 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xe832 (36/160)
Dec 14 20:02:38 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xe932 (40/160)
Dec 14 20:02:38 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Dec 14 20:02:38 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xe932 (40/160)
Dec 14 20:02:38 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xea32 (44/160)
Dec 14 20:02:38 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Dec 14 20:02:38 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xea32 (44/160)
Dec 14 20:02:38 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:02:38 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:02:38 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:20:01 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xe832 (36/160)
Dec 14 20:20:01 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Dec 14 20:20:01 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xe832 (36/160)
Dec 14 20:20:01 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xe932 (40/160)
Dec 14 20:20:01 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Dec 14 20:20:01 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xe932 (40/160)
Dec 14 20:20:01 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xea32 (44/160)
Dec 14 20:20:01 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Dec 14 20:20:01 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xea32 (44/160)
Dec 14 20:20:01 acsd: acs_candidate_score_intf(1112): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:20:01 acsd: acs_candidate_score_bgnoise(1577): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:20:01 acsd: acs_candidate_score_txop(1835): eth7: txop check failed for chanspec: 0xeb32 (48/160)
Dec 14 20:22:49 bsd: bsd: Sending act Frame to ac:67:84:64:9e:32 with transition target eth7 ssid fc:34:97:39:98:64
Dec 14 20:22:50 bsd: bsd: STA:ac:67:84:64:9e:32 no response
Dec 14 20:22:50 bsd: bsd: Sending act Frame to ac:67:84:64:9e:32 with transition target eth7 ssid fc:34:97:39:98:64
Dec 14 20:22:51 bsd: bsd: STA:ac:67:84:64:9e:32 no response
Dec 14 20:22:55 hostapd: eth6: STA ac:67:84:64:9e:32 IEEE 802.11: disassociated
Dec 14 20:22:55 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind AC:67:84:64:9E:32, status: 0, reason: Previous authentication no longer valid (2), rssi:-32
Dec 14 20:22:56 wlceventd: wlceventd_proc_event(530): eth7: Auth AC:67:84:64:9E:32, status: Successful (0), rssi:0
Dec 14 20:22:56 wlceventd: wlceventd_proc_event(559): eth7: Assoc AC:67:84:64:9E:32, status: Successful (0), rssi:-26
Dec 14 20:22:56 kernel: wl0: random key value: 378640D5874F1D54789B013C9225F5A63900EB2E5D250B127F51BB9B2056F3F2
Dec 14 20:22:56 hostapd: eth7: STA ac:67:84:64:9e:32 IEEE 802.11: associated
Dec 14 20:22:56 hostapd: eth6: STA ac:67:84:64:9e:32 IEEE 802.11: disassociated
Dec 14 20:22:56 wlceventd: wlceventd_proc_event(511): eth6: Disassoc AC:67:84:64:9E:32, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Dec 14 20:22:56 hostapd: eth7: STA ac:67:84:64:9e:32 RADIUS: starting accounting session 1BF871A4B75D2BC7
Dec 14 20:22:56 hostapd: eth7: STA ac:67:84:64:9e:32 WPA: pairwise key handshake completed (RSN)
Dec 14 20:22:56 dnsmasq-dhcp[1852]: DHCPREQUEST(br0) 192.168.50.201 ac:67:84:64:9e:32
Dec 14 20:22:56 dnsmasq-dhcp[1852]: DHCPACK(br0) 192.168.50.201 ac:67:84:64:9e:32 Chromecast
Dec 14 20:23:19 kernel: wl0: random key value: 266442334F2EB6A8577201123158CCA8ADF35DF141C20EC2D96D4A5BF61F7B03
Dec 14 20:23:19 hostapd: eth6: STA 50:e0:85:b9:82:05 IEEE 802.11: disassociated
Dec 14 20:23:19 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 50:E0:85:B9:82:05, status: 0, reason: Unspecified reason (1), rssi:0
Dec 14 20:23:19 wlceventd: wlceventd_proc_event(530): eth7: Auth 50:E0:85:B9:82:05, status: Successful (0), rssi:0
Dec 14 20:23:19 wlceventd: wlceventd_proc_event(540): eth7: ReAssoc 50:E0:85:B9:82:05, status: Successful (0), rssi:-57
Dec 14 20:23:19 hostapd: eth7: STA 50:e0:85:b9:82:05 IEEE 802.11: associated
Dec 14 20:23:19 hostapd: eth7: STA 50:e0:85:b9:82:05 RADIUS: starting accounting session D62C21B311754CE2
Dec 14 20:23:19 hostapd: eth7: STA 50:e0:85:b9:82:05 WPA: pairwise key handshake completed (RSN)
Dec 14 20:23:19 dnsmasq-dhcp[1852]: DHCPREQUEST(br0) 192.168.50.92 50:e0:85:b9:82:05
Dec 14 20:23:19 dnsmasq-dhcp[1852]: DHCPACK(br0) 192.168.50.92 50:e0:85:b9:82:05 DESKTOP-SE1ATCV
Dec 14 20:23:22 dnsmasq-dhcp[1852]: DHCPREQUEST(br0) 192.168.50.92 50:e0:85:b9:82:05
Hello all,
When you installed the router, did the default/reset router configuration "drop the Internet" (whatever that means)?
OE
I’ve been having the same issue for a while. Factory reset with initialize, latest Merlin, disabling 160mhz, etc. Issue still exists.
Wired connections are fine. But WiFi will drop the internet connection when doing teams/zoom calls or stop loading stuff like TikTok or Reddit if rapidly scrolling through images or video. Like, WiFi remains connected but just no internet connection.
Also have a GT-AX6000 (Factory reset with initialize, latest Merlin). Doesn’t have any issues like this despite even having 160mhz band switching on. I’m guessing the AX86U is faulty or something.
(both routers have 5ghz/2.4ghz separated, smart connect disabled etc.)
Edit: I haven't had time to look into this specific issue but after searching "AX86U wifi 388.1" on these forums it appears that many users have been reporting the same behavior on the latest Merlin. Some have resolved by locking channels or rolling back the firmware. You should try locking your wifi channels to specific ones or rolling back the firmware. I might try it tonight if I'm bored.
I have the same problem. It seems to be common. I tried switching from stock to merlin and still suffer the wifi "stalling". My computer remains connected to the wifi but the internet halts for a bit. Sometimes it comes back sometimes it doesnt. Always fixed by disconnecting and reconnecting to the wifi. There are a few other posts with the same problem here
Have you tried rolling back the FW or locking your channels?
I have only tried the above and disabling smart connect. I do live in a very congested area do you think the channel changing constantly is why there is a problem?
Based on what others have reported you should try locking to specific channels. Then if that doesn’t work try going back a FW version.
So far my best success is with the default WIFI settings! Yes, that means Dual Band SmartConnect and no DFS channels. I usually disable WPS but since the last reset even that is on. Several have been beating their heads trying to do 160 MHz but they either have environment issues or they have fooled with the settings. Yes, my 5 GHz channel does change and the router drops back to 80 MHz when no 160 MHz client is active. Locking the 5 GHz channel with 160 MHz is sure to result in lost connectivity when your router detects RADAR! With the SSID on both bands a dropped 5 GHz connection can switch to the 2.4 GHz and keep working!
Same problem here. AX86U, absolutely perfet, but the last (!) firmware that works without this issue is the 386.5_2 Merlin. After it, every firmware has this "bug". I have 31 devices, 4 VMs, 5 wired the rest on Wifi, and the issue present only on my Samsung Galaxy S22 Ultra. I tried everything, factory reset, Merlin firmwares, ASUS firmware, I have to go always to 386.5_2.
I also have the same problem on my AX86U - setting the channel to rigid solves this problem a bit.
The wifi connection is good and the ping on the router's gateway disappears from time to time.
I have similar issue too, with 388.1 on my AX86U. Wifi remain connected by not internet connection at intermittent intervals. Even Speedtests for wired LAN & Wifi aren't consistent. Downgraded to 386.7_2 and everything back to super smooth.
I was having issues up until yesterday when I loaded this firmware. 3.0.0.4.388_22068-gf3adbcd.
I am not sure if its new, but it came straight from me updating firmware asus when logged into router
I've been experiencing this with RT-AC5300 with both factory latest & Merlin stable firmware (currently 386.7_2) .
Deauth_ind xxx, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-69
May  4 22:05:21 WAN Connection: WAN was restored.
When the issue occurs, one or more of the clients will show extremely low Link rates e.g. 10kb up / down on the admin page.
I believe the issue is related to smart connect. Clicking "restore default settings" on Tools --> smart connect rules tab will resolve the issue for a while.
My theory is that smart connect is sending incorrect instructions to the client, and the client deauth fails + sets a reduced media rate on the new channel.
I was receiving this same behavior; however, my environment is set up is a little different. Please forgive me, I'm not a network engineer and I'm not very versed in ASUS's firmware / configurations. I am an IS Engineer but I more specialize in the server, client, windows side.
Setup:
1 ASUS AXE11000 Router
2 ASUS ET8 Mesh Nodes
I am not using radius to auth. I set my networks to WPA2 due to compatibility issues with WPA3 on my home automation switches and I think hybrid mode was maybe causing issues.
Here is what I tried which seems have resolved the issue.
  1. Factory reset the router and nodes without porting over the previous configs.
  2. I split the channels and disabled smart connect so I could be careful about what I installed on the 2.4Ghz, 5Ghz, and 6Ghz networks.
  3. I rolled back my firmware to the oldest firmware available for my devices for both the mesh nodes and router.
  4. I locked my control channels for all bands so that they weren't constantly changing.
  5. I found 1 problem device (a kasa smart bulb) that seemed to be causing deauth auth messages. There are other devices too but this one was a problem child. I replaced it with a smart switch instead.
  6. Hardwired and moved one of my mesh nodes
  7. Kept AIProtect Disabled
After 6 months, I believe by network is finally stable (I'll assess over the next few days and assess. Interestingly enough, I found more useful information about what to try on pages related to other models than my model itself so posting this here.
I'm not sure which of these fixed it yet... but after it's stable for a few more days, I intend to upgrade the firmware to the latest to see.
In my case Orbit Hobbit and Aqara M1S hub were continuously disconnecting; the only settings that fixed it was disabling ax/wifi6 SUPPORT, any other setting didn't do jack.
I'm trying to enable AX just for the 5ghz band, and keep the 2.5 disabled but I need to disable smart connect to do so.
By the way as I write everything works
Keep you posted
New update, just for the orbit hobbit (b-hyve) I had to disable universal beamforming too for stability, now after 24 hours straight zero disconnection so far.
next steps:
- enable wpa2/wpa3 encryption
- disable smart connect
- enable ax support for 5ghz network only
so the expectation is having 2.4 network for legacy devices, so all the settings aim for compatibility and, concerning the 5 network for performance
@RMerlin is it possible to have smart connect enabled and moving the ax support option to the professional tab so we can select it per network type?
Thank you
