Release ASUS RT-AX86U Pro Firmware version 3.0.0.6.102_34406 2025/10/28
bbunge
Part of the Furniture
Version 3.0.0.6.102_34406
58.21 MB
2025/10/28
SHA-256 :A96AD6D8E21F44591E7285984F8A25655DE8492C5E435D5803E1574B9CB3C4D7
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
(Having problems with the download link)
Asus support page: https://www.asus.com/us/networking-...86u-pro/helpdesk_bios?model2Name=RT-AX86U-Pro
Well there you go… here it is. just had to be patient.
Tried to upgrade the node. Got a firmware upgrade unsuccessful. :-(
Edit: for some reason my Mac had problems unzipping the file. Trying again with the node.
All is well. Router and AiMesh node upgraded! Am surprised that there was no recommendation to factory reset and use a 10 digit password.
