Asus RT-N66U N900 + Asuswrt-Merlin repeater mode?
ABH
Hello,
I'm planning on purchasing the Asus RT-N66U N900 and running Asuswrt-Merlin.
Do router and OS support bridge mode? I have a repeater at home to help extend my Wi-fi signal to the ground floor.
My current set up consist of two Linksys Wirless G WRT54GL v1.1 routers. One of them is acting as a repeater.
Thanks in advance!
i dont see the logic in this as the n66u is a quite old wireless N series router that doesnt have the greatest coverage anyway and then running an even older wireless G router in repeater mode that halves the throughput will just end up with the same crap wifi speed and throughput
do yourself a massive favor and get a wireless AC router that may just cover the whole house and have no need for a repeater in the first place
to your actual question just to answer it how is the wrt54gl doing repeating ,, are you using wds mode or do you have 3rd party firmware on it like dd wrt and using repeater bridge mode
if its wds you can prob forget it as wds is pretty redundant these days , if its dd wrt and repeater bridge then it doesnt matter as the wrt54gl is just working like a wifi client and can connect to any upstream wireless router
Hi, thanks for your reply. Can you recommend a good wireless AC router?
