Asus RT87U wifi region
Chrismallia
Hi I am buying Asus rt87u and as I am in Malta the store orders it from Europe. The question I have will the wifi only be restricted to Europe? coz as I see in the 87u wifi settings you can not change wifi region as other routers, as set to Europe the signal is very weak. Thanks regards
You would probably need to pull your cfe from your router and edit it with the appropriate region and load it back on. Then factory reset the router so it loads the appropriate region.
Hi thanks for your reply, can you tell me how to do that? or is there any guide? thanks again
