Beta Asuswrt-Merlin 3004.388.11 Beta is now available
RMerlin
Asuswrt-Merlin dev
Staff member
Asuswrt-Merlin 3004.388.11 beta is now available. The focus of this release is merging a new GPL (largely security fixes), the removal of AiCloud due to repeated security issues, and the new Traffic Monitor redesign that was initially introduced in 3006.102.
Changes:
3004.388.11 (xx-xxx-2025)
  - NOTE: AiCloud has been removed from Asuswrt-Merlin due
          to its poor security track record.  This also includes
          cloud syncing features such as Asuswebstorage or
          Dropbox syncing with USB folder.  Use a VPN if you
          need secure remote access to your data.
  - NOTE: For developers, the Tomato legacy files (tm*.*)
          are no longer included with the webui.  Please
          update your addon pages accordingly.
  - NEW: Redesigned Traffic Monitor pages.
         - Uses Chart.js for Realtime and Last24 pages
         - Removes legacy Tomato code
         - Last 24 can be zoomed in and panned (mouse wheel
           and pinch-to-zoom gestures are both supported)
         - Realtime and Last 24 now show as bits/s instead
           of bytes/s
         - Settings moved from the tab to the dropdown menu
         - Removed NVRAM database location option and added
           JFFS.  Also removed rarely used start-of-month
           setting.
  - UPDATED: Merged GPL 388_25575.
  - UPDATED: OpenVPN to 2.6.17.
  - UPDATED: libcap-ng to 0.8.4 (to be in sync with upstream)
  - UPDATED: Dropbear to 2025.89.
  - UPDATED: nettle to 3.10.2.
  - CHANGED: TrafficMonitor stats can now be saved to JFFS,
             and removed support for saving to NVRAM.
  - FIXED: IPv6 blocking of DoT servers (dave14305)
  - REMOVED: outdated setuprsa.sh script.
  - REMOVED: AiCloud support, due to security reasons.
Please keep discussions on this specific release. Off-topic posts will be either ignored or deleted.
Downloads are here.
Changelog is here.
Reserved post.
Thanks, updated AX86U, works well just as Alpha before
