Release Asuswrt-Merlin 3006.102.7 is now available
Subject: RT-AX86U Pro (3006.102.7): Dual WAN Load Balance broken & Failover requires reboot
  • It feels like the routing table or conntrack is not being properly flushed/updated when WAN settings change in this build.
Has anyone else noticed this behavior on the 3006 branch? Any suggestions on how to force a routing table flush via SSH without rebooting every time would be greatly appreciated.
@Saulus, I also have a RT-AX86U Pro with Load Balance enabled and I agree with at least some of your findings. According to my observations, ip rules are not properly cleaned up when one of the Dual WAN connections is stopped, restarted, etc. Starting with one of the earlier 3006.102.x versions (my guess is .6), the behavior has drastically changed when compared to past versions.
As far as I understand, Dual WAN is closed source, but I'm confirming some of reported issues in case @RMerlin is able to check what is happening to the ip rules after a notify_rc stop_wan_if or a notify_rc restart_wan_if.
Thanks in advance.
