Release Asuswrt-Merlin 3006.102.7 is now available
got sloppy and forgot to detach the nas before upgrading. all went well thankfully but we still have the logging off glitch when doing a "rescan" of the nas. too insignificant to sweat though.
. . . as always, many thanks to the wizardry of merlin for releasing this maintenance update so quickly.
3006.102.7_2 is now available.
Shows 102.7 still after update... I'll redownload and try again, I'll leave this here just in case. BE88U
Edit:
So two attempts and both to no avail, not even the 'applying settings', just the please wait and then a reboot..
Then I downloaded the OneDrive version and it worked first time.. verily odd.
I have an ASUS RT-BE7200 (Best Buy Version) / RT-BE88U router.
I am seeing an interesting issue for the first time. I did a dirty upgrade, but did do a reset afterwards as well and have the same problem (Considering downgrading but want advice before I do).
The router does not have an issue on regular reboot through the UI.
But if the router looses power and the modem (Arris S34) stays on, then when the router turns back on the time is out of sync (its Dec 31, 2023).
NTP sync keeps failing, and since time is incorrect, the router is unable to actually get a connection to the internet through the modem and unable to sync with NTP service going into a loop of incorrect time and no internet.
Setting the time manually over ssh does did not fix the issue.
Powering off both the modem and the router, and then turning them on at the same time did fix the problem, and the time magically gets set (I am assuming no internet on the modem on reboot somehow delays the NTP sync? not sure).
Have been able to reliably reproduce this issue twice now.
Never had this issue with the previous version of the firmware, 102.6.
Hmmm, similar issue with AT&T BGW320-500 and three different brand routers now. Finally figured out that the routers were provided IP Passthrough address correctly, BUT no Internet service, (red WAN LED on all three), until I used the Broadband Restart option on the BGW GUI. Yes the date was December 2023 but I think around the 15th.
It took me the whole weekend to finally reach that solution....
I have this set but it does not seem to be picking up since it's not blocking adult content
