Release Asuswrt-Merlin 3006.102.7 is now available
Hi RMerlin and everyone!
I’ve just updated my RT-AX86U Pro to the new 3006.102.7_2 version. In the previous release (.7), I had a lot of trouble setting up Dual WAN (Load Balance).
Before I try to configure everything again, I want to ask:
Does the Load Balance mode work now without dropping the connection?
Is it still mandatory to fill in the 'Destination IP' field in Routing Rules, or can it be left empty now?
Do I still need to reboot the router every time I change the Primary WAN provider?
I am not an advanced user and I don't use SSH, so I just want to know if the Web Interface and the switching logic are working correctly now. I don't want to mess up my settings if these issues are still present.
Thanks for any info!
My BE92U keeps crashing (5th so far) with the 102.7_2 and only change beside the firmware updates is I've onlined an 8th IOT device to the 2.4GHz network. Conincidentally, I had a previous 8th device on the network but disconnected it over the winter. I don't know for sure if this is causing the CPU stalls as I did have some stability for a period of time. Will take the newest addition off the network to see if that resolves it.
Mar 25 10:18:20 asusroot: Clock check: Current year is 2026, Router uptime:  10:18:20 up  2:01,  load average: 0.18, 0.21, 0.24
Mar 25 10:23:20 asusroot: Clock check: Current year is 2026, Router uptime:  10:23:20 up  2:06,  load average: 0.19, 0.25, 0.25
Sep  2 22:45:00 kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Sep  2 22:45:00 kernel: rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
Sep  2 22:45:00 kernel: rcu:     (detected by 1, t=900704567728 jiffies, g=1565161, q=82497)
Sep  2 22:45:00 kernel: rcu:     (detected by 0, t=900704567728 jiffies, g=238861, q=87)
Sep  2 22:45:00 kernel: rcu: INFO: Stall ended before state dump start
Sep  2 22:45:00 kernel: rcu: All QSes seen, last rcu_sched kthread activity 900704567728 (905007233726-4302665998), jiffies_till_next_fqs=3, root ->qsmask 0x0
Sep  2 22:45:00 kernel: tdts_core_ioctl_udb_op_prog_ctrl() fail!
Sep  2 22:45:00 kernel: amas_portstatus R  running task        0  4230   4202 0x00400000
Sep  2 22:45:00 kernel: Call trace:
Sep  2 22:45:00 kernel:  dump_backtrace+0x0/0x150
Sep  2 22:45:00 kernel:  show_stack+0x14/0x20
Sep  2 22:45:00 kernel:  sched_show_task+0x100/0x120
Sep  2 22:45:00 kernel:  rcu_check_callbacks+0x798/0x810
Sep  2 22:45:00 kernel:  update_process_times+0x2c/0x70
Sep  2 22:45:00 kernel:  tick_sched_timer+0x54/0xd0
Sep  2 22:45:00 kernel:  __hrtimer_run_queues+0x13c/0x1d0
Sep  2 22:45:00 kernel:  hrtimer_interrupt+0xe4/0x2b0
Sep  2 22:45:00 kernel:  arch_timer_handler_phys+0x30/0x40
Sep  2 22:45:00 kernel:  handle_percpu_devid_irq+0x80/0x140
Sep  2 22:45:00 kernel:  __handle_domain_irq+0x70/0xd0
Sep  2 22:45:00 kernel:  gic_handle_irq+0x5c/0xc0
Sep  2 22:45:00 kernel:  el1_irq+0xe8/0x190
Sep  2 22:45:00 asusroot: Clock check: Current year is 1918, Router uptime:  22:45:00 up 10424 days, 21:56,  load average: 1.84, 0.38, 0.12
Sep  2 22:45:00 crond[4137]: time disparity of 15011749 minutes detected
Sep  2 22:45:00 kernel:  __memset+0x170/0x188
Sep  2 22:45:00 kernel:  kernfs_seq_show+0x28/0x30
Sep  2 22:45:00 kernel:  seq_read+0x150/0x4e0
Sep  2 22:45:00 kernel:  kernfs_fop_read+0x24/0x1e0
Sep  2 22:45:00 kernel:  __vfs_read+0x2c/0x150
Sep  2 22:45:00 kernel:  vfs_read+0xa8/0x130
Sep  2 22:45:00 kernel:  ksys_read+0x60/0xe0
Sep  2 22:45:00 kernel:  __arm64_sys_read+0x18/0x20
Sep  2 22:45:00 kernel:  el0_svc_common+0x70/0x170
Sep  2 22:45:00 kernel:  el0_svc_compat_handler+0x1c/0x30
Sep  2 22:45:00 kernel:  el0_svc_compat+0x8/0x34
Sep  2 22:45:00 kernel: rcu: rcu_sched kthread starved for 900704567830 jiffies! g238861 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x200 ->cpu=0
Sep  2 22:45:00 kernel: rcu: RCU grace-period kthread stack dump:
Sep  2 22:45:00 kernel: rcu_sched       R    0    11      2 0x00000008
Sep  2 22:45:00 kernel:  __switch_to+0xe8/0x170
Sep  2 22:45:00 kernel:  __schedule+0x214/0x5a0
Sep  2 22:45:00 kernel:  schedule+0x38/0xa0
Sep  2 22:45:00 kernel:  schedule_timeout+0x15c/0x2a0
Sep  2 22:45:00 kernel:  rcu_gp_kthread+0x488/0x900
Sep  2 22:45:00 kernel:  kthread+0x118/0x150
Sep  2 22:45:00 kernel:  ret_from_fork+0x10/0x24
Sep  2 22:45:00 hostapd: wl1.1: STA 84:0f:4c:48:51:c4 IEEE 802.11: associated (aid 7)
Sep  2 22:45:00 hostapd: wl1.1: STA 84:0f:4c:48:51:c4 IEEE 802.11: Could not add STA to kernel driver
Sep  2 22:45:00 hostapd: wl2.1: STA 14:35:b7:33:33:5c WPA: group key handshake completed (RSN)
Sep  2 22:45:00 hostapd: wl1.1: STA 84:0f:4c:48:51:c4 IEEE 802.11: disassociated
Sep  2 22:45:00 asusroot: Year is 1918 (less than 1969) – restarting router
Sep  2 22:45:00 hostapd: wl1.1: STA ec:a9:07:2b:6e:1e WPA: group key handshake completed (RSN)
Sep  2 22:45:00 hostapd: wl1.1: STA 04:99:b9:61:a2:38 WPA: group key handshake completed (RSN)
Sep  2 22:45:00 hostapd: wl1.1: STA e0:2b:96:b5:3f:8f WPA: group key handshake completed (RSN)
Sep  2 22:45:00 hostapd: wl1.1: STA 3c:e9:f7:48:1d:ef WPA: group key handshake completed (RSN)
Sep  2 22:45:00 rc_service: Rebooting...
Sep  2 22:45:00 kernel: sysrq: SysRq: intr handled on CPU 3
Sep  2 22:45:00 kernel: sysrq: Emergency Sync
Sep  2 22:45:00 kernel: Emergency Sync complete
