Tobias McNulty
I finally upgraded from the 376.49 series yesterday to 378.54_2. Everything seems to be working great except for local DNS (and yes I did a factory reset after the upgrade).
$ host foo.mydomain.lan
Host foo.mydomain.lan not found: 3(NXDOMAIN)
Where "foo" is the hostname I gave to the DHCP client for my laptop and mydomain.lan is the domain name configured for the DHCP server. This used to work without a hitch, though I seem to remember some oddness with requiring the host to have obtained a DHCP lease before DNS would be served (I've confirmed that it has in fact obtained a lease). Simply using "host foo" gives the same result.
Any idea what might be causing this?
Thanks,
Toby
Thanks,
Toby
