BACKUPMON BACKUPMON v1.9.0 -Sep 6, 2025- Backup/Restore your Router: JFFS + NVRAM + External USB Drive! CIFS/SMB/NFS! (Available in AMTM!)
Many thanks for your work on this. I am trying to get this to backup to a share on my Unraid server (on the same LAN) as well as another USB that is plugged into my router.
I am actually trying to get the other USB to work first then will tackle the network share.
I cannot figure out how to configure the tool to do the backup on another USB plugged into the same router? I am sure it is obvious but I just can not figure it out - sorry!
I figured it out. I did not get what "Target Media Type" was...my bad. I should have clicked but it did not hit me that was how to swap to a USB target (it is now obvious). Thanks!
You're welcome! Make sure that the "Backup Target Media Type" is set to "USB", and make sure you're picking the right one. Seeing that you have 2 plugged in, it should give you a choice. Definitely work on the network share... that's a good place to put these backups.
Sorry I didn't see your second post... you're right on the money!
Do I need to configure anything?​
You can enter the setup screen with the command 'backupmon.sh -setup' or by hitting the 's' key within 10 seconds of the backup starting:
Hitting the "sc" option, there are currently 15 items you can configure.
I'm definitely looking for your feedback... what works, what doesn't... what else would you like to see. But all-in-all, as good ideas come up for things to possibly add, very much a WIP (work-in-progress). ;) Lots more stuff to come... I'm looking at adding a way to add some functionality to schedule the backups in CRON... so check back soon!
More Information:
1.) How does it all work? In TLDR; format, when BACKUPMON runs a regular backup, it will create a daily folder under the folder structure you have defined for it to connect to on your network share. So for example today, on September 4, 2023, it would create a /04 folder (if you're on a "Monthly" frequency), where its backups will get dumped into.
2.) Backup Retentions- there are 4 different kinds depending on your preference:
  • "Weekly" retention would write "Mon, Tue... Sun" folders.
  • "Monthly" would write daily "01, 02, 03... 30, 31" folders for each day of the month,
  • "Yearly" would write "001, 002, 003... 364, 365" folders for each day of the year.
  • "Perpetual" would write a unique folder based on date/time, such as "20230909-092511".
At this time, "basic mode" (explained below in more detail) will back everything up in 1 week, month or year cycles, and will overwrite the backup files each time it comes across the same day in its cycle, unless you've chosen the "Perpetual" retention, in which case it keeps backups forever under its unique folder structure. In "advanced mode", it does not overwrite backups in your weekly, monthly and yearly folders, and keeps everything forever... Here's a screenshot of what your backup folders on your network share might look like (please note there's a bit of a mix between "Monthly" and "Perpetual" retention backups as I was testing... :)
3.) Backup copies - During a backup, BACKUPMON will also copy over a copy of 'backupmon.sh', 'backupmon.cfg', any optional TAR exceptions list you have defined, a text dump of your NVRAM, and a copy of restore "instructions.txt". (see above) Within this instructions.txt file, you will find the same instructions you see on screen during a restore, telling you what steps need to be taken for a successful restore. In it, is also your latest external USB drive label, which must be duplicated when you format a new USB drive, and want to restore your backup to it.
4.) The optional TAR exclusion list can be placed in a directory of your choice. PLEASE NOTE: By default, backupmon will back up everything, swap files, log files, included! It is a good idea to exclude these using this exclusion list file. You may encounter issues restoring backups if you try to restore a swap file to an already existing swap file on your router. You can create this file anywhere, but I prefer to keep things in /jffs/addons/backupmon.d and named it "exclusions.txt", just to clear the clutter. The contents of this file is simply a list of files that TAR can safely ignore during a backup. Certain files, like your swap file, or other temporary files, aren't needed when restoring a backup, and get recreated after a restore. As of v1.42, the swap file is being excluded from backups unless you override this option (#9) in the config menu. Huge thanks to @visortgw for sharing his exclusion file... the default exclusion items list looks something like this:
exclusions.txt
myswap.swp
entware/var/log/*
skynet/skynet.log
entware/var/lib/unbound/unbound.log
*.tar
*.gz
Save this file somewhere on your router, and make sure it's properly referenced in BACKUPMON. Eliminating swap and other temp files could really speed up your backups tremendously, and save you from headaches down the road on a restore.
5.) The Basic vs Advanced Mode differences are described below:
BASIC
- Only backs up one backup set per daily folder
- Backup file names have standard names based on jffs and USB drive label names
- Self-prunes the daily backup folders by deleting contents before backing up new set (N/A when 'Perpetual Retention' is enabled)
- Will overwrite daily backups, even if multiple are made on the same day (N/A when 'Perpetual Retention' is enabled)
- Restore more automated, and only required to pick which day to restore from
ADVANCED
- Backs up multiple daily backup sets per daily folder
- Backup file names contain extra unique date and time identifiers
- Keeps all daily backups forever, and no longer self-prunes
- Will not overwrite daily backups, even if multiple are made on the same day
- Restore more tedious, and required to type exact backup file names before restore
6.) Manually Purging Perpetual Backups -- Under the config menu, when selecting "perpetual" backup retention, you will have the option to choose whether you want to enable backup purging for everything older than a certain number of days. Once configured, you can manually access the purge backups functionality under the operations area under the setup menu. This function will step you through multiple prompts before committing to delete any backups, and will show you which backups are affected. PLEASE NOTE: deleting backups is permanent, and advise caution on what you are deleting, and ensure that the list presented to you is what you want deleted. Also, PLEASE NOTE: if there are any backups that you want to save or store for later use, PLEASE move these to a SAFE and otherwise secure location outside of the backup folder structure that BACKUPMON utilizes, else there will be a chance these backups will get deleted.
Automatically Purging Perpetual Backups -- if you have enabled "Perpetual Backups", and "Purge backups", and run BACKUPMON with the -backup switch (ie. "sh backupmon.sh -backup"), then it will auto purge your backups after it finishes your normal backup. This was done to make it simpler when running this under a daily CRON job to not only back up but purge as well with one command.
See screenshot below as an example:
7.) Commandline switches - When running backupmon with a switch, you can utilize other functionality that is normally only available through the UI. Here is an explanation of what each switch does:
sh /jffs/scripts/backupmon.sh -- Running the script with no switches simply runs the primary and secondary backups (no auto purge).
sh /jffs/scripts/backupmon.sh -setup -- This displays the setup + operations menu
sh /jffs/scripts/backupmon.sh -backup -- This runs the normal primary and secondary backups, and runs auto purge
sh /jffs/scripts/backupmon.sh -restore --This initiates the restore procedure, allowing you to pick from primary or secondary backups
sh /jffs/scripts/backupmon.sh -purge -- This runs the auto purge routine against the perpetual backup folders
sh /jffs/scripts/backupmon.sh -secondary -- This runs the secondary backup only, and does not perform auto purge
B&W Mode: You can now optionally run a monochrome color scheme for those who are capturing screen output by using a secondary -bw switch after any of the other primary switches. Example:
sh /jffs/scripts/backupmon.sh -backup -bw -- This runs the normal primary and secondary backups, and runs auto purge in B&W mode!
Reading your restore instructions - a couple of questions
. If going from usb flashdrive to usb ssd - I assume you use amtm to format ssd as one partition and label the same ie Merlin
. how do you verify that jffs scripting is enabled
. How do copy the backupmon.sh and .cfg fiile from the server to the router? I have tried using scp but I get
sh: /opt/libexec/sftp-server: not found
Regards
P
That's correct. Keep that label the exact same. If you want to rename it after the restore, that's perfectly fine.
If you've used AMTM to format the drive, then jffs scripting is automatically enabled. You can verify under administration->system tab
I would give the winscp client a try. I've had good luck with that. Perhaps that give you a different result?
Would love a config item that allows to run a script on start, success, failure so that I can integrate this into healthchecks.io and monitor my backups
BACKUPMON will exit with an error code of "1" if something went wrong, and "0" if it was successful. You can always try doing it that way. Here's an example:
#!/bin/sh
echo -e "\nBackup Started"
sh /jffs/scripts/backupmon.sh -backup >/dev/null
BE=$?
echo -e "Backup Finished\n"
if [ $BE -eq 0 ]; then
  echo -e "Backup Completed Successfully\n"
else
  echo -e "Backup Failed\n"
fi
exit 0
Here's the script for anyone else who needs something similar
#!/bin/sh
# Define hostnames and corresponding Healthchecks.io URLs
HOSTNAME=$(hostname)
ROUTER1="https://hc-ping.com/XXXXXXXXXXXX"
ROUTER2="https://hc-ping.com/XXXXXXXXXXX"
ROUTER3="https://hc-ping.com/XXXXXXXXXXXXXXXX"
# Set the backup directory and successful backup threshold
BACKUP_DIR="/jffs/backups"
TRACKING_FILE="/jffs/scripts/backup_success_count"
X_SUCCESSFUL_BACKUPS=14
# Determine the correct Healthchecks.io URL
case "$HOSTNAME" in
  "ROUTER1")
    HC_URL=$ROUTER1
  "ROUTER2")
    HC_URL=$ROUTER2
  "ROUTER3")
    HC_URL=$ROUTER3
    echo "Unknown router hostname: $HOSTNAME"
    exit 1
esac
# Send a ping to Healthchecks.io to indicate backup start
wget -qO- "$HC_URL/start" >/dev/null
echo "Backup Started"
BE=$?
echo "Backup Finished"
  echo "Backup Completed Successfully"
  wget -qO- "$HC_URL" >/dev/null  # Success ping
  # Increment the success counter
  if [ ! -f "$TRACKING_FILE" ]; then
    echo 1 > "$TRACKING_FILE"
  else
    SUCCESS_COUNT=$(cat "$TRACKING_FILE")
    SUCCESS_COUNT=$((SUCCESS_COUNT + 1))
    echo "$SUCCESS_COUNT" > "$TRACKING_FILE"
  fi
  # Check if cleanup is needed
  if [ "$SUCCESS_COUNT" -ge "$X_SUCCESSFUL_BACKUPS" ]; then
    echo "Cleaning up old backups..."
    ls -tp "$BACKUP_DIR" | grep -v '/$' | tail -n +$((X_SUCCESSFUL_BACKUPS + 1)) | xargs -I {} rm -- "$BACKUP_DIR/{}"
    echo 0 > "$TRACKING_FILE"  # Reset the counter
  fi
else
  echo "Backup Failed"
  wget -qO- "$HC_URL/fail" >/dev/null  # Failure ping
fi
exit 0
I am doing USB backups with BACKUPMON 1.8.22 on a RT-AX58U with 3004.388.8_4-gnuton1
I have been using BM so far without much trouble but now I am having some error like this one: FAILURE: Error creating EXT USB tar file :confused:
I started having these errors since yesterday 29th.
error log
Mar 30 2025 03:53:29 RTAX58U BACKUPMON[22461] - tar: write error: Broken pipe
Mar 30 2025 03:53:29 RTAX58U BACKUPMON[22461] - **ERROR**: Errors detected creating EXT Drive tar file.
log
2590 Mar 30 2025 01:58:16 RTAX58U BACKUPMON[7815] - INFO: External drive (USB) mounted successfully as: /tmp/mnt/backup
2591 Mar 30 2025 01:58:17 RTAX58U BACKUPMON[7815] - INFO: Finished backing up JFFS to /tmp/mnt/backup/router/AX58U-Backup/30/jffs.tar.gz
2592 Mar 30 2025 01:58:17 RTAX58U BACKUPMON[7815] - INFO: Finished integrity check for /tmp/mnt/backup/router/AX58U-Backup/30/jffs.tar.gz
2593 Mar 30 2025 01:58:18 RTAX58U BACKUPMON[7815] - INFO: Finished backing up NVRAM to /tmp/mnt/backup/router/AX58U-Backup/30/nvram.cfg
2594 Mar 30 2025 01:58:18 RTAX58U BACKUPMON[7815] - INFO: Finished copying routerfw.txt to /tmp/mnt/backup/router/AX58U-Backup/30/routerfw.txt
2595 Mar 30 2025 01:58:18 RTAX58U BACKUPMON[7815] - INFO: Starting backup of EXT Drive on Sun Mar 30 01:58:18 CET 2025
2596 Mar 30 2025 03:06:52 RTAX58U BACKUPMON[7815] - **ERROR**: Errors detected creating EXT Drive tar file.
2597 Mar 30 2025 03:06:56 RTAX58U BACKUPMON[7815] - INFO: Email notification was sent successfully [FAILURE: Error creating EXT USB tar file].
The problem seems backing up EXT Drive to /tmp/mnt/backup/router/AX58U-Backup/XX/amtm.tar.gz
That amtm.tar.gz went from 670MB the 28th to 501MB the 29th and seems to be corrupted.
Scanning the drive for archives:
1 file, 525451264 bytes (502 MiB)
Testing archive: \\RTAX58U\router (at backup)\AX58U-Backup\29\amtm.tar.gz
Path = \\RTAX58U\router (at backup)\AX58U-Backup\29\amtm.tar.gz
Type = gzip
Headers Size = 10
T amtm.tar
ERROR: Unexpected end of data : amtm.tar
Sub items Errors: 1
Archives with Errors: 1
Sub items Errors: 1
2: Fatal error occurred,
I checked the SSD with builtin health scanner without errors being reported.
ntfsck 3021.4.15.3
Checking NTFS Superblock ...
Device name        : /dev/sda2
NTFS volume version: 3.1
Cluster size       : 4096 bytes
Current volume size: 19987427840 bytes (19988 MB)
Checking system files ...
Current device size: 19987430400 bytes (19988 MB)
Checking for bad sectors ...
Checking attributes ...
  0.00 percent completed
  0.30 percent completed
  0.61 percent completed
100.00 percent completed
Checking directory structure ...
Checking $MFT bitmap ...
Checking for orphaned files ...
Scanning orphaned files completed.
Checking cluster allocation ...
Checking cluster allocation bitmap ...
Space in use       : 19988 MB (100.0%)
Done NTFS checking and repair on device '/dev/sda2'.
Syncing device ...
@bidh 670MB is one huge backup. What data are you backing up and what's the size of the drive you're backing up to? My backups don't exceed 30MB.
error log
Agreed with @Ripshod... that is a pretty huge backup for just a router environment. Both my router's backups hover between 40MB and 50MB. My guess is that you're either running into a file issue on the source, like an extremely long filename/folder, a corrupt file/folder, or some kind of network issue at the time that this is running. Do you see anything in your syslog from around that same time?
If you are able to still get a file list out of that broken .tar file (using the tar -t command), you should be able to see what the last file was that it tried to add, and lets you see what may have come next, giving you some clues to go on.
Yeah, I noticed that.
I just did thanks.
Once the 670 MB amtm.tar.gz is decompressed,
That amtm folder holds an amtm.tar file about 4.26GB.
And inside there's the same structure.
The thing is there are 2 json files 1.5GB and 2.5GB in /tmp/mnt/amtm/entware/etc/AdGuardHome/data
About 15 millions lines logged.
I guess I should have paid attention to AGH Query log rotation. :oops:
I purged those files.
And it works.
The backup is now 40.4MB.
I double checked my exclusion file
 1 myswap.swp
 2 router/AX58U-Backup/*
 3 entware/var/log/*
 4 skynet/skynet.log
 5 entware/var/lib/unbound/unbound.log
 6 *.tar
 7 *.gz
 8 *.tmp
I just did thanks.
And it works.
 1 myswap.swp
 3 entware/var/log/*
 4 skynet/skynet.log
 6 *.tar
 7 *.gz
 8 *.tmp
Nice sleuthing. You might want to add the following to your exceptions list so your backups don't continue to grow if those .json's continue growing in the future. (unless you've taken care of the log rotation now) Don't think these would be needed if you ever had to do a full restore.
*.json
*.json.1
Nice sleuthing. You might want to add the following to your exceptions list ....
*.json
*.json.1
I don't think it's a good idea to add such a blanket exclusion rule (e.g. "*.json") that targets all JSON files because some of them may actually be useful/needed.
For instance, when users have custom icons for their client devices, there's a JSON file in the directory as well:
It's better, IMO, to exclude specific files by explicitly adding their directory paths.
My 2 cents.
My 2 cents.
Very true... should not have made it all-inclusive like that. @bidh... I'd heed that advice and make sure there's a path on there if you do leave it in your exceptions file.
I didn't set a path but excluded querylog.json* just in case other scripts also have this type of logs.
 1 myswap.swp
 3 entware/var/log/*
 4 skynet/skynet.log
 6 *.tar
 7 *.gz
 8 *.tmp
 9 querylog.json*
Your choice would work, but I'd go with
entware/etc/AdGuardHome/data/querylog.json*
and keep it precise. We can't be sure what other bits of code rely on a querylog.json being present currently, and in the future.
Is there an easy way to completely disable backups for an external USB storage? It seems that it currently requires adding every folder to exceptions, which is not very convenient. Would it be possible to implement a toggle for that? I don't need to back up my external drive because it's mostly used as temporary storage for files that get periodically uploaded to AWS, and they are pretty big.
Have you modified your exclusions file? You can add a directory to exclude there. That would probably work 🙂
Edit: NVM I see you already mentioned added directories to exclude.
