pedeb04
My primary backup config below.
The backup gets saved on the Network drive that gets mounted and unmounted on /tmp/mnt/backups
All works ok.
customizable parameters that affect the operation of the primary backup.
: BACKUPMON Version : 1.8.22
: Source Router Model : RT-AX86U_Pro
: Source Router Firmware/Build : 3006.102.4_0
(1) : Source EXT USB Drive Mount Point : /tmp/mnt/Merlin
(2) : Backup Target Media Type : Network
(3) : Backup Target Username : peter
(4) : Backup Target Password (ENC) : c21ic2FtYmEK
(5) : Backup Target Path : \\\\192.168.50.46\\RouterUSB
|---- NFS Mount Options? : N/A
(6) : Backup Target Mount Point : /tmp/mnt/backups
(7) : Backup Target Directory Path : /router/RT-AX86U_Pro_Backups
(8) : Backup Exclusion File : /jffs/addons/backupmon.d/pfexclusion.txt
(9) : Backup Swap File : No
(10) : Backup CIFS/SMB Version : 2.1
(11) : Backup Retention : Yearly
|---- Purge Backups : No
|---- Purge older than (days) : N/A
(12) : Backup/Restore Mode : Basic
(13) : Schedule Backups : No
|---- Time: : 2:30
|---- Scheduled Backup Mode : Backup Only
(14) : AMTM Email Notifications : Yes
|---- On Success : Yes
|---- On Failure : Yes
(15) : Secondary Backup Config Options : Disabled
(s) : Save Config & Exit
(e) : Exit & Discard Changes
For the secondary config
1 Enabled
2 USB
3 router user
4 router password
selection: 6
Select a Secondary Target USB Backup Drive Mount Point:
1. /dev/sda1 on /tmp/mnt/Merlin type ext4
2. /dev/sdb1 on /tmp/mnt/backups_usb type ext4
Enter selection:[1-2] [e=Exit]?
I choose 2
I thought it do a secondary backup to USB backups_usb
But by having the USB plugged into the router the primary backup errors umount: can't unmount /tmp/mnt/backups: Invalid argument which is where the network drive is mounted. I don't understand why the USB would cause this issue.
The reason I went down this secondary backup option was I don't always have my server on and I noticed with MerlinAU will try to do a backup before updating the firmware. And seeing the router is always on it can do the backup there if the server is off.
All works ok.
|---- Time: : 2:30
1 Enabled
2 USB
3 router user
4 router password
selection: 6
I choose 2
