To manually Assign IP around the DHCP list, I added "dhcp-hostsfile=/jffs/etc/dnsmasq/static_leases" to /jffs/configs/dnsmasq.conf.add and created a script (/jffs/etc/dnsmasq/static_leases) that contains 1 record for each IP I want to assign.
Record Example: E8:39:35:CC:E7:34,HP Printer,192.168.1.246,10080m
When I reboot the router these names are not assigned and the system log file indicates "bad DHCP host name at line n of /jffs/etc/dnsmasq/static_leases" for each entry.
I know the names are fine because I can manually enter them on the LAN/DHCP Server page. Seems I must have an error in the way I structured this script file.
Anyone know what I have wrong in the record structure in this file??
Using N66U router with Firmware:3.0.0.4.374.39 (Merlin build)
