[Beta] RT-AC87U/RT-AC3200 9.0.0.4_378_9481 Beta for checking bug in Traffic Analyzer -> Statistic
Ok thanks. But problem with not change colors also is postpone ?
I don't see any problem in changing colors, could you post your picture about this? If your bug isn't as this bug:
10. when "Display for" is app, select the fifth app in top 5 chart, and then change "Display for" back to router, if router's client is less than 4 client, will show the old fifth app traffic in top 5 chart.
=> It should be fixed.
Please give more specific information, or I can't do anything, wording can't let R&D realize what user encounter, give me picture or anything useful. Or you can write down your testing steps, it will be very useful to debug.
Thanks,
Vanic
But problem with color is in FW 9383. In 9366 is OK.
For date 15.12.2015
Then change date to 14.12.2015 and select client green LG G3S
Then again change date to 15.12.2015 and first client name DS713 show in RED (name) and Green (statistic data). All should be in RED color.
@Piter :
Thanks for your information, I will inform related R&D to check code, it must be code-asynchronous.
Thanks,
ASUSTek Inc.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
i can confirm that bug in fw 9383
On 9366 this bug not exist.
Hi all,
I think the two issues are the same, I can duplicate. They can happened at the same time.
1. 12/16/2015 + apps + click green color
2. select today 12/16/2015 again
3. show first device name + green (two errors all happened!)
Thanks,
Vanic
Yes you are right... it is the same bug
I tested new beta 9457 and in this beta is still problem with colors in TA :)
Hi all,
I think it needs more time to fix bug for related R&D because he is busy in other tasks. And we have known what happened.
Thanks,
Vanic
Ok we are waiting...
Hello Vanic... we are waiting for correct problem with colors. Because i update to Official version 9460 and in this FW still is problem with colors after go to other date and come back to today...
The related R&D has no time to handle now, I can't interrupt anything. Just waiting as I ...
Thanks,
Vanic
Hi all,
Bug has fixed, I have uploaded the beta firmware.
Thanks,
Vanic
And i am waiting to add this fixes from this FW to official FW not new beta.
Is this new beta 9481 is merged with beta 9460 with fixed issue of Network Map http://www.snbforums.com/threads/be...0-beta-for-checking-bug-in-network-map.29269/ ? Or it is other branch as official 9460 ?
Ok i check it. And it is not the same branch a beta 9460. In this newer 9481 is not contains new more icon for client...
I don't think making demands towards ASUS developers like that is a proper way to approach this issue...there are processes the code must go through before a full release can be made, including QA and proper release processes. These can take days, even weeks to complete. ASUS would not invest their time on these fixes just to never release them in a full release. Be patient.
i install new fw 9481 and found bug when i add dhcp/static device
i think that mac adres whois is copied to description field
next. device icon is different than in beta fw 9460
I come back to beta 9460. Still wait when Asus official fix 5GHz with new driver. This durring very long...
in this beta no changes in network map from 9460.....
Yes
FW BETA 9460 is other branch than FW Beta 9481. Not good
I think that all FW should be create on the same branch. Should have alle fixes.
exactly. IMO this is a source of problems, with branch synchronizations.
