SoCalReviews
SSID: kick_that_ball_in_my_garden_again_and_lose_it
Yep. Michigan and Marietta Georgia are the only two with 10 in stock now. The Ohio store sold one. Guess I'm easily entertained to be checking Microcenter stock levelsWell..the crappy n66u i got rid ran 7 years without issues...ill take my chances.
Yep and one of those microcenters is in Michigan..lol
That's quite the SSIDSSID: kick_that_ball_in_my_garden_again_and_lose_it
Out of curiosity, what HW revision is your reliable AC86U? In case I end up going that way. ThanksI actually returned 3 ax86u due to kernel cpu crash within 2 to 3 days of using stock asus firmware. Speeds were the same as my ac86u and also my two ax devices were connecting at 80ghz instaed of 160ghz.
All 3 were rev 1.0 and think it's either my baduck or a bad run of serial numbers.
How do I turn off Tree Spanning?Whitey019 - I turned off "Spanning-Tree Protocol" and that seemed to have helped my speed test on LAN. my wifi is still 400/150 on my iPad Pro (wifi AX, 5 ft from the router) but tests on LAN seem better on upload now.
Model year 2020...will check on hw rev when I get a chance.Out of curiosity, what HW revision is your reliable AC86U? In case I end up going that way. Thanks
I only know it from the Merlin firmwares.Can it be enabled/disabled via the command line?
I think so. Here is an example:Can it be enabled/disabled via the command line?
www.snbforums.com
nvram show | grep stpHere's another reference thread. Also full of Tech9's warnings, which I'd advise respecting at least until others weigh in. I'm not expert enough to judge.How do I turn off Tree Spanning?
www.snbforums.com
Welcome To SNBForums
