[Bug] RT-N66U 380.69 Time Mangement Parent Control not working
slingshot
Thanks for the great firmware. There is a bug in the 380.69 release.
It is not possible to enter the Time Mangement fora device any more in the parent control area.
The following JavaScript error is thrown in the browser.
Uncaught TypeError: Cannot read property 'split' of undefined
at gen_lantowanTable (ParentalControl.asp:410)
at HTMLInputElement.onclick (ParentalControl.asp:1)"
Hope this can be fixed in the next release.
Cheers,
Slingshot
Make sure your client name doesn't contain any special characters....only alpha numerics, dash and underscore.
Merlin had been fixing a lot of these parsing issues, but I suspect some may have crept back in when he pulled in some of the 382 webui to the 380 release.
I have deleted the device from the list and hit apply.
I have added the device again with the same name and hit apply.
No it's working again with the same name!
Thanks for the support.
Hi
I have similar issues with 380.69 for R7000
My parental control tab is gone at all.
How I can restore access to this tab?
Thank you,
Arek
Asuswrt-Merlin isn't supported on the R7000. If you want support you should ask the person that created that firmware.
