TheLyppardMan
I've just uploaded firmware 386.2 Alpha 1 to my RT-AX88U. Can anyone tell me where to find Cake-QOS as I thought I had read that it could be managed from within the GUI?
Adaptive qos > qos > cake.I've just uploaded firmware 386.2 Alpha 1 to my RT-AX88U. Can anyone tell me where to find Cake-QOS as I thought I had read that it could be managed from within the GUI?
Oh thanks - I've found it now. I didn't expect to see it amongst all the Trend stuff and was looking for a separate tab for it.Adaptive qos > qos > cake.![]()
It's a new feature in the latest Alpha build.not aware of a gui for CakeQOS (or is it new in alpha?)
see below for info
CakeQOS - CakeQOS-Merlin v1.0.8
Current Version (386.1_2 firmware): 1.0.8 - run script update as detected The 1.0.8 release provides fixes for a couple issues: New cake binaries for 386 firmware (thanks Odkrys) Fixes for AX58U/AX3000 wan interface on eth4 (thanks Adamm & dave14305) *** Special credit to @dave14305 with...www.snbforums.com
GitHub - ttgapers/cakeqos-merlin: Custom add-on for supported Asus routers with Merlin firmware that introduces CAKE QoS as an alternative to Traditional/Adaptive/FreshJR implementations.
Custom add-on for supported Asus routers with Merlin firmware that introduces CAKE QoS as an alternative to Traditional/Adaptive/FreshJR implementations. - ttgapers/cakeqos-merlingithub.com
once installed, run cake-qos via cli and use menu options
Select an option
[1] --> Start cake
[2] --> Stop cake
[3] --> Check cake status
[4] --> Change cake settings
[5] --> Update CakeQOS-Merlin
[6] --> Install CakeQOS-Merlin
[7] --> Uninstall CakeQOS-Merlin
[e] --> Exit
Just let it do its stuff after setting your download/upload speed and WAN packet overhead. That's the beauty of Cake, install and forget.Oh thanks - I've found it now. I didn't expect to see it amongst all the Trend stuff and was looking for a separate tab for it.
Just a few more question if I may - is Cake configurable or do I just let it do its stuff with the setup that has been installed? If the answer is yes, what would I be able to configure and how would I go about it?
I've just updated to the 386.2 Merlin firmware and Cake is now an option in the QOS page and I have selected it.
But I'm now not sure how to actually see if it's working, I know there is no GUI (yet), but can somebody please explain how I see the Cake stats from the CLI?
The statement above says "once installed, run cake-qos via cli and use menu options" but I can't seem to run cake-qos from anywhere, and can't find the location it is installed.
Sorry, I'm not very experienced with CLI commands, so am probably missing something pretty obvious.
Richard
I'm assuming you are saying I need to install the V2 Alpha Script?
To see the status of CAKE without the addon script, run these commands over SSH:Just so I understand, was Cake actually working silently in the background even without installing the V2 alpha script?
tc -s qdisc show dev eth0 root
tc -s qdisc show dev ifb4eth0 root
Welcome To SNBForums
