Can I speed-test the different VPN connections?
Mikii
Hi guys,
I downloaded and installed speedtest.py
(https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py)
and it is working fine.
The question is: there any way to test the connection speed of my different VPN connections?
How can I run it so that it will test, for instance, my tun11 or my tun12 connection speed?
maybe there Is a way to set the bash environment so that all the bash commands will be run through a specific tun connection?
Thank you for your time.
These are my current TUN11 settings (ip changed)
tun11 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.123.58.24 P-t-P:10.123.58.24 Mask:255.255.254.0
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:324835 errors:0 dropped:0 overruns:0 frame:0
TX packets:422675 errors:0 dropped:2484 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:252356810 (240.6 MiB) TX bytes:341997242 (326.1 MiB)
MIC
set default route through tunnel 1 - run speed test
set default route through tunnel 2 - run speed test
Hi agilani, thank you for your reply.
This looks simple but I am not sure I understand. How do you "set default route through tunnel 1" ?
