Can't connect from back in time to SSH server
zerophase
I'm trying to send my ssh key to the HDD I have connected to an ac66u router. I've had no problem logging in and running commands over SSH through putty. Once I try to send the key over with ssh-copy-id -i ~/.ssh/id_dsa.pub <server>@<host> I've been failing to resolve the host name.
Have any idea on how to get into the partition I'm using to back up to? I keep trying different combination of /dev/sda4, /tmp/mnt/sda4, and such and each one gets rejected.
**Update: OK, I managed to get the public key sent over. Ended up getting a few error messages from Back In Time. Installed all of the packages it needs on the router, but I'm running into problems with this error message:
find PATH -type f -exec chmod u-wx {} \;':
find: unrecognized: -type
BusyBox v1.20.2 (2015-06-10 22:21:23 EDT) multi-call binary.
The manual mentions I need to change the default shell from /bin/sh to /opt/bin/bash in /etc/passwd. I also need to add /opt/bin:/opt/sbin: to the start of the PATH environment variable in /etc/profiles.
manual mentions I could need to reinstall the ssh server if I setup the links wrong. Is there a safe way to do this to entware?
**Update 2: Ok, I've tried changing the paths and break the entware install each time. I've had to reformat the JFFS partition a few times trying to route my backup through the router. Does anyone know the correct way to modify those paths to keep entware operational?
