Can't login a new tablet to 87U
inPicton
Is there a trick I don't know about? I click on the ssid and enter password. Won't connect. Very frustrating. Is there a setting inside router I'm unaware of?
Have tried Guest network, too.
Am using 380.58
Thank you, Paul.
Is your new tablet up to date with its firmware (os)?
Does your ssid or the password contain any special characters?
Have you tried resetting the tablet's network settings?
I would suggest upgrading to 380.59, reset to factory defaults and then minimally and manually configure the router to secure it and connect to your ISP, in addition to using new ssid's (alphanumeric only) and you can use the same password if it is alphanumeric already.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
Thank you, thank you both for that great info. I used a password without any trick characters and you will never guess what happened: I'm in!
I have save both threads to Evernote.
Now I understand why someone else in this building can't log in. I will also upgrade to the latest firmware.
Best regards, Paul.
Paul, glad you solved this. ;)
Hey, that's funny. Ya, I solved it. That deserves an LOL.
Regards, Paul.
You did. ;)
You took new information and applied it to your situation and came out ahead. There are some that don't or won't do this to 'help themselves'.
I was sincere in praising you initially. Still am.
