www.snbforums.com
Do you have a T-Mobile branded (TM-AC1900) router? And if so was it properly jailbroken including the MTD5 partition fix? If not properly jailbroken one cannot flash later versions of Asus or Asus-Merlin firmware to the TM-AC1900 router. Example method of jailbreaking that specific router:Please help, my RT-AC68U cannot be updated for a long time, the last fw is 386.7.
cat /dev/mtd5 > /jffs/mtd5_backup.bin
mkdir /tmp/asus_jffs
mount -t jffs2 /dev/mtdblock5 /tmp/asus_jffs
rm -rf /tmp/asus_jffs/*
sync && umount /tmp/asus_jffs
rm -rf /jffs/.sys/RT-AC68U
nvram unset fw_check && nvram commit && reboot
Unfortunately it didn't helpWelcome to the forums @fluikes69.
Issue Updating Merlin Firmware to 386.12_2 on my ASUS RT-AC66U B1
ello forum members, I'm currently facing an issue while attempting to update my ASUS RT-AC66U B1 router with Merlin firmware version 386.12_2. It seems like the update isn't going smoothly, and I could use some assistance and guidance on how to resolve this. Here's what I've done so far: I...www.snbforums.com
As per the previous post, is your router a T-Mobile branded (TM-AC1900) model?Unfortunately it didn't help
RT-AC68U_386.12_4.trx.
Welcome To SNBForums
