koonthul
Hello all - thanks in advance for the help. I'm a beginner, so go easy. I've done a lot of research and need guidance on next steps in order to solve my problem as I'm not sure what to do next.
Problem:
I'm trying to run a simple CAT5e cable from my router to an endpoint (laptop with wired connection) and get Gigabit speeds. Can't seem to get it to register at 1 gigabit though, only says 10/100 (in windows). Trying to figure out what to do next.
Some more information:
1. The cable i'm using is an old Belkin cable and it's labeled for 5e on its side. I cut it in half and then terminated both ends MYSELF to verify all 4 twisted pairs are tight with no gaps between the cable and termination. My cable tester (although cheap) registers all 8 wires as connecting properly on both ends. Cable tester does not test for speed or anything else. That all checks out so i'm pretty sure my terminations with RJ45 plugs (3 prong) using the T568B standard are good. 1 half of it registers gigabit, so I don't THINK the cable is the issue. Here's what the side of the cable has printed on it...
2. The original cable itself was too long, so I cut it in half as I only needed about 50 feet or so. As a test, I took the other half (longer) of the cable that I didn't run, terminated both ends and tested it between router and end point. REGISTERS 1 GIGABIT just fine.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
3. The part of the cable that I did run is only through the floor boards of my house, around some of the duct work for the HVAC system and alongside some other (dead) wiring. It is not parallel to any particular AC cabling and only crosses some AC cabling at one point.
4. I've verified on more than one laptop that the bad cable still registers at 10/100 rather than gigabit.
5. I just noticed the 6728 FT part on the cable, but I know this cable is WAY shorter than that. I think total we are talking 150 ft maybe, not even. That's BEFORE i cut it in half (almost). I know I had this cable as far back as 2008 or so...I think.
Questions on next steps...
I'd really like to NOT re-run this cable and would like to figure it out. Here are some guesses.
1. When I ran the cable, I may have crimped/bent it when running it over the HVAC system. How would i test for broken or bad connections in the middle of the cable? My internet sleuthing has turned up a test that I could do with a standard multimeter (which i have) by shorting the ends of each twisted pair and seeing its resistance (ohms) readout on the other end, but I'm wondering if there is anything I can try using my PC/ Laptop and router first that would be easier? Again, my cable tester didn't show anything broken so I'm hesitant to try this.
2. My terminations are bad, even though my tester says they pinout correctly. Thoughts on this? I could re-terminate each end, but am trying to be smart about this. Reason I haven't is because the tester tells me my pins are lined up, so again i'm leaning away from this option.
3. How would i figure out if there is interference of some kind? Is there a way to test for this other than ripping the cable out? I suppose the ohms test in #1 might show me whats up? Again, don't want to cut off my terminations again but I'm leaning this way for both #1 and this test.
Here's the small crimping kit and tester kit that I bought for this project. I really like the crimper, as it does passthrough and feels solid (to me at least). Tester is garbage cheap but does what I wanted.
Thanks for any advice. My last resort (obviously) is to re-run the cable but I'd rather learn something first![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Problem:
E158012 Verified (UL) & (ETL) CMR Category 5E 350 MHZ TO TIA/EIA-568B . 2 24 AWG 4 UTP C(UL) 06728FT
