I have a question on the CFE I need for my bricked router.
Router model is a RT AC68u E1, I bought it from eBay knowing it was bricked. Boots up with one usb light on and the power led dimly lit. Any network cable plugged in lights the appropriate led.
So far I have managed to desolder the nand and dump the contents. The nand does not seem to match the board, probably not a surprise, the board has Rev 1.90 silk screened on it. The dumped nand has a variable HW 1.70 in it.
My question, can I purchase a working E1 router, dump the nand and write that to my corrupt nand then reinstall? I understand if this works I will have a clone, I'd need to swap data to make the router unique again.
Thanks in advance for any help.
