Hi, I have noticed some strange behavior when using the Family filter CleanBrowsing‑1 applied at the WAN level or through DNS Director.
When using the Safari browser in Private mode, the DNS filter can be bypassed and adult sites are not blocked.
If I change the DNS filter to CleanBrowsing‑2, AdGuard, or ControlD, then the Private tab cannot bypass the filter. This issue only occurs when CleanBrowsing‑1 is selected.
I get the same results if I apply the DNS filter at the LAN level through DNS Director.
DNSLeakTest shows that the Private tab in Safari bypasses the filter by using Apples Relay (Apples Private Relay is disabled in settings), which is expected. However, it is strange that this bypass does not occur when any of the other filters are selected. In those cases, DNSLeakTest shows that the family DNS filters are working correctly.
I tried with FW 3004.388.10 and 3004.388.11
Also, I am locked into using Safebrowsing-1 as this is the only family filter that allows comments on YouTube.
