Cloudflare being rerouted by my ISP
andresmorago
Hello
Im aware this is more related to cloudflare than asus merlin firmware but still wanted to consult here.
I noticed a couple days ago that latency to 1.1.1.1 significantly increased from 40ms to 90ms. After doing some checks, i noticed that my ISP is rerouting all the 1/8 network via United States and not Colombia. I have 2 closer cloudflare servers with lower latency than Atlanta server.
Besides contacting my ISP, i was wondering if there is any way i could force 1.1.1.1 requests to go to my closest server located on my city.
thanks
You will likely find it is using DoT that is causing this distant routing. I have the same issue with Quad9 in the states. I have not contacted my ISP about this but it might be worth a try...
Sent from my SM-T380 using Tapatalk
i will contact my ISP. i do think this is a long shot but what the heck.
regarding my setup, what if i replace 1.1.1.1 for the IP of the cloudflare closest server (104.17.209.9) at my routers WAN page?
Cloudflare DNS is running over their CDN, so hope this helps..
