Compatibility with ZenWiFi AX6600
Eodyne
Is Merlin compatible with the ZenWiFi AX6600. I see compatibility with for AX 6000 and I just wanted to check if that included everything "under" 6000 (i.e. 6600) before trying to install it. I'm using a 6600 as a AiMesh node.
Welcome to the forums! Unfortunately you are out of luck... here's a list of compatible models: https://www.asuswrt-merlin.net/about
When purchasing a new router, the first thing I look at is this list... then I dive even further into which one of these is the best bang for the buck (which these forums are great for), and would try to find the one with the longest possible time where it would be supported by Merlin firmware...
