Another vote here for plastic conduit. The wider the better.
Metal conduit may require grounding according to your local code. Plastic will not.
You may also want to check if there are code requirements to run "plenum" conduit, which will not give off poisonous fumes in a fire. I suspect that means polythene tubing, rather than PVC, but you may want to check. Where I live they are coloured differently.
The great advantage of putting cables in tubes is that when the next networking technology arrives, you can simply pull the new type of cable (or fibre?) into the tube without reopening the walls. And of course for an additional TV you can pull coax through the tubes instead, if you wish.
The empty conduit costs very little, so you can lay lots of empty conduit and pull cable through when and where you need it, at a later date. As said above, it helps if you put string in the empty tubes as you lay them, which will help pull through the cable later.
Single strand ethernet cable is not meant to be bent repeatedly, so it will be more reliable to terminate each cable with a Cat 6 face plate at one end, and at the other end run each cable to a central location and install a patch panel.
