Solved Configure dnsmasq to have larger cache-size and persist on reboot?
BikeHelmet
Howdy all,
I think I'm hitting a DNS edge case. I know the default 1500 cache size is enough for 99% of home users, but I'm pretty sure I'm that sub-1% edge case and need to modify the config file.
What's the best way to accomplish this? /etc/dnsmasq.conf is not in JFFS, so it can't easily be modified/saved? I saw a thread saying to create a new /jffs/configs/dnsmasq.conf.add file and add lines there, but that adds lines - as in, I end up with two cache-size entries.
I'm sure a linux guru will be able to tell me the best method in about 15 seconds, and then I'll just Putty/WinSCP in and get it done. :) Cheers!
Threads that I was reading:
Use a post conf script instead and change the cache value.
Details are here
Perfect! Got it done, thanks. :)
/jffs/scripts/dnsmasq.postconf
    #!/bin/sh
    source /usr/sbin/helper.sh
    . /opt/share/diversion/file/post-conf.div # Added by Diversion
    pc_replace "cache-size=1500" "cache-size=4000" "/etc/dnsmasq.conf"
