Confused about gateway IP
austin17427
I'm not sure if this is the right place to post this question.
I have a RT-AC66U with 374.43_53D7j9527 (Merlin LTS fork) installed, firmware (3.0.0.4.374.43_53D7j9527) is the latest from August 2022.
I added YazFi script, and now I'm migrating my subnets from 192.168.1.0/24 to 10.x.x.x/24
I thought I successfully migrated guest and IoT networks but I see below entry in my Tasmota which made me think there's something wrong.
IP Address (wifi)10.x.x.x
Gateway192.168.x.1
Subnet Mask255.255.255.0
I didn't expect to see 192 address on the gateway??? I thought it would be 10.x...
What am I missing here? Maybe I need to migrate all networks and re configure router to use 10.x address and then it will all be set right? But I wanted to get an opinion before going that far.
Thank you.
Edit: Strange but when I connect my iPhone to the guest network, gateway is 10.x.x.x It's confusing to see 10.x on the phone and 192.168.x.x on the IoT device.
You could change the guest to match the 10.0.0.0 or change the guest back to the 192.168 and route it out the 10 subnet with a static route.
