Hi, I’m looking at a Cudy 2.5G unmanaged switch primarily for size and cost. There’s a couple of threads which refer to tp-link switches being able to pass VLAN tags through; but trendnet switches not.
www.snbforums.com
www.snbforums.com
Does anyone know if Cudy switches have this capability. I l really like the small form factor and it needs to go in a cupboard with little room. Thanks!
Any Cudy switch users out there? Heat, noise of they have a fan,
AI-MESH with Multiple GuestNetworkPro - Auth Failure on AX86U_Pro
Hi all, I've a strange behavior with the following constellation: 1 * AX88U Pro (Router) 1 * AX6000 (Node) 2 * AX86U Pro (Nodes) When I configure the Guest Network Pro with an aditional WLAN to the normal WLAN, it's not possible to connect through the AX86U Nodes. I've tried different WLAN...
AiMesh with Guest WiFi and a Switch - Configuration and Best Practices
My Setup - looking for some advice on configuration and best practices. Apologize for long post and my obvious lack of knowledge AiMesh I have an ASUS RT-AX86U (regular not the pro) on latest stock asus firmware. This is the main node I have aimesh node ASUS RT-AX58U I have aimesh node ASUS...
