Voxel Custom firmware build for Orbi LBR20 v. 9.2.5.2.26SF-HW
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/c...bi-lbr20-v-9-2-5-2-24sf-hw.73983/#post-708327
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-lbr20-v-9-2-5-2-25sf-hw.74426/
New version of my custom firmware build: 9.2.5.2.26SF-HW.
Changes (vs 9.2.5.2.25SF-HW):
1. Toolchain: Go is upgraded 1.7->1.17.2.
2. wireguard-tools package is upgraded 1.0.20210424->1.0.20210914.
3. DNSCrypt Proxy v.2 is upgraded 2.1.0->2.1.1.
4. OpenVPN is upgraded 2.5.3->2.5.4.
5. wget package is upgraded 1.21.1->1.21.2.
6. lighttpd package is upgraded 1.4.59->1.4.61.
7. proftpd package is upgraded 1.3.7b->1.3.7c.
8. bridge-utils package is upgraded 1.7->1.7.1.
9. curl package is upgraded 7.78.0->7.79.1.
10. gdbm package is upgraded 1.19->1.19.1.
11. cifs-utils package is upgraded 6.13->6.14.
12. bind package is upgraded 9.9.8-P3->9.17.19.
13. libuv and libnghttp2 packages are added (used by bind).
14. bind package is changed to use OpenSSL 1.1.1.
15. coreutils package (sort/gnu-date) is upgraded 8.32->9.0.
16. haveged package is upgraded 1.9.14->1.9.15.
17. ethtool package is upgraded 5.13->5.14.
18. nano package is upgraded 5.8->5.9.
19. jansson package is upgraded 2.13.1->2.14.
20. libiconv-full package is upgraded 1.11.1->1.16.
21. Fix build by GCC 10.x (Host Debian Buster->Host Debian Bullseye).
22. Kernel level optimization.
23. iptables: add missed mods.
24. Host tools: upgrade bison to 3.8.2.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Sarasam69
Hello.
I am having issue update from netgear to voxel.
I did downgrade to 2.5.2.4.
I connect via lab cable to rbs and trying to upload voxel rbs. After many attempts it still shows same 2.5..2.4.
the message shows successful update. But firmware still shows 2.5.2.4.
Shouldn’t it show voxel one? Starting with 9.2….,
Skippy Bosco
Hello.
1) From a computer connected to your Orbi network, browse to http://orbilogin.net and log in using your orbi admin id and password.
2) Browse to the Advanced tab then Administration -> Firmware Update
3) Click Manual Update on the right side
4) Update your satellites 1 at a time using the check box to the left and pushing the Update button on the right.
5) A separate box will pop up requiring you to log in again. Read the messages you are presented with to select the Voxel update file and upload.
6) Wait for your satellite to finish rebooting and then update any other satellites, then finally your router.
