bengalih
I setup separate dhcp servers for my guest wifi networks similar to the process described here:
https://github.com/RMerl/asuswrt-me...dicated-DHCP-options-bind-to-a-specific-SSID?
The dnsmasq.postconf in that link doesn't work for me exactly, I needed quite a few differences in my iptables/ebtables rules, but for sake of simplicity this is the idea behind what I'm doing. That article also states that you should create a services-start script to do a service restart_dnsmasq to "to ensure the DHCP service is restarted after the WiFi interface have been mounted."
I have set that up, however it appears that it isn't delaying appropriately, as everytime I reboot my system I am not able to get IP addresses on the guest Wifi until I go and manually issue a service restart_dnsmasq on my server.
Is there a better way to configure this so that I don't need to do this manual step each reboot?
