Disable regular wifi network, Enable only Guest
CrazyAmber313
Hey,
I own Asus RT AC86U , recently I installed Merlin on it , and Yafzi.
I need only the Guest Wifi to be on , no need in the regular one.
but if I disable the radio- the guest network is also disabled.
Is there any way to leave only tthe Guest network on ?
Thank you.
No, because the guest WiFi interfaces are virtual interfaces attached to the physical WiFi interface. Just give the primary WiFi SSID a bogus password. You could probably hide the SSID if you wanted to.
Thank you ,
WIll it interfere with the Guest network performance?
Could one use the regular WLANs as guest WLANs?
OE
Depends on what you are trying to do! In Wireless>Professional>Set AP Isolated that would mean WiFi clients can't access each other. But using YazFi streamlines and improves how the guest networks work. Horses for courses, different people will prefer different solutions!
The ability to allow selective access in YazFi is a killer ability!
