Disabling NAT-PMP on GT-AX11000
Doug Nix
I use Fing to monitor my network. Recently, I ran a router vulnerability scan and got a message that my router allows unchecked NAT-PMP port forwarding. I went hunting for guidance and found this:
[Wireless] How to disable NAT-PMP from ASUS Router?​
I followed the procedure in the FAQ and found that all of the settings on my router were as shown in the ASUS FAQ. The router still fails the Fing scan. Any thoughts on how to correct this problem?
If you have the "Open NAT" tab check that "Enable Port Forwarding" is turned off there as well.
Hey, Colin,
I do have OpenNAT, but port forwarding was disabled. I‘m also usIng symmetrical NAT, not full-cone.
Thanks, @ColinTaylor. I'd searched the Fing fora, but somehow I missed that post. I've added my voice to the thread. If I hear of a fix from Fing, I'll post the details in this thread.
Here’s the workaround. It’s not clear to me whether or not there is a real NAT-PMP vulnerability here.
it seems to be related to the Aura RGB feature on the router. Aura RGB let’s you run colours and patterns on the router’s RGB LEDs. Fun, but not anything more than window dressing. From the web UI, disable the Aura RGB function.
Start by logging in to the router using SSH or telnet. At the command line enter:
nvram get aurasync_enable
If the result is = 1, then the Aura function is still enabled. To fix that, enter:
nvram set aurasync_enable=0
commit
The commit command will make sure that the change persists after a reboot. You can check that the parameter is correctly set by running the first command again. It should come back = 0.
Reboot the router.
Once the router is back up, open FING and run the router vulnerability test in Fing’s Security tab. It should come back without any errors now.
I’ve finally been able to report this as a potential security vulnerability to ASUS via their vulnerability reporting site. We'll see if they respond. If I hear anything from them I will update this thread with details.
On May 16, 2022 I received an email from ASUS Security that included a link to download a beta firmware version that corrects the problem with the apparent NAT-PMP vulnerability. I've installed and tested the firmware, and it appears to do the trick. Here's the link: https://www.asuswebstorage.com/navigate/a/#/s/E01336E2A1D645678E142FFC3F5A160FY
Not sure if/when these changes will be included in the production version of the firmware.
C Disabling NAT (as "secondary" router) ASUS Wi-Fi 13
