Diversion Diversion v other ad blocking options
TheLyppardMan
I tried Diversion quite a while ago, but now that we have other router-based options, I use those instead. My current setup uses Quad9 as the default, with AdGuard set for mobile phones. I use the uBlock Origin browser extension for Windows laptops on my network. I'm just curious as to how Diversion compares with the setup I have just described.
Two years ago I switched from Diversion to NextDNS.
I was very satisfied with Diversion and its blocking of advertisement.
But NextDNS offers other very interesting features, like DNSSEC and TLS over HTTPS and much more. As far as blocking of ads I am subscribed to oisd blocklist through NextDNS and it is working perfectly.
I using Quad9 as my default DNS resolver with AdGuard for just some non-Windows devices. These are the settings I currently have.
Nothing works better than uBlock Origin, where available. If you want ad-blocking to what can't run uBlock Origin - just send the device to AdGuard DNS in DNSFilter. You get the same results without running any scripts. No USB stick required either.
Yes, that's what I thought. That was why I set things up like that and it seems to be working really well.
I've been running NextDNS, but wanted to switch to ControlD for lower latency/more I just upgraded from ac68u to ax88u to have quad core CPU and 1GB of RAM to run Diversion, other entware modules, but now you're telling me not to because NextDNS/ControlD is doing a better job? :)
