Diversion Diversion v5.6 [2026-Apr-12] - the Router Ad-Blocker
Well done on providing the router details and FW version straight up, they are excellent clues.
Let us know how you get on!
Wow, thanks for the thorough reply!
I finally got back around to it this morning. Upgrading to 386.14_2 took a couple of tries, as did the factory reset. I selected the backports repository when installing Entware this time, and Diversion appears to have installed successfully. I can't say for sure whether it was the firmware upgrade, the factory reset, or the Entware repo that did the trick, but it's working now! Thanks so much!
Diversion 5.5 is now available
  • Fixes the half finished amtmupdate feature introduced in Diversion v5.4.8 to be compatible with the "Automatic Script Updates" feature in amtm.
  • Adds option in d menu to enable/disable amtmupdate by amtm.
don't seem to be able to update diversion 5.4.9 to 5.5 , it goes through the motions reboots, but still reports the older version, any tips please ?, obviously I am doing something wrong.
If you used "u" try "uu".
What is the reason Diversion gives that it requires a reboot?
Diversion 5.6 is now available
  • Removes the option d, 11 to disable amtmupdate in Diversion, use option in amtm instead.
  • Some visual, wording and coding changes here and there.
