icanfly
Hi
Ive posted a lot of questions today apologies for that this is the last issue I'm having:
ASUS RT-AX88U on latest Merlin 3004.388.6
I use the router as the DNS server. I set hostnames for all my physical devices in DHCP, I set my domain name (mydomain.net) which is also my public domain name
LAN IP
Host name: router
RT-AX88U's Domain Name: mydomain.net (which is also my public domain name)
DCHP Server
Hide DHCP/RA queries : No
Default Gateway: <ROUTER IP ADDRESS>
DNS Server 1 <BLANK> but I did put in the router IP Address to test if it would work
Advertise router's IP in addition to user-specified DNS: No (But I also tried changing it to Yes)
in WAN:
Forward local domain queries to upstream DNS: No
Everything works great normally. I also have a lot of custom hostnames set in jffs/configs/dnsmasq.conf.add which point to my docker containers
But I discovered today if I unplug my wan port and have no WAN all of my local dns hostnames wont resolve and resolve back to like 10.0.0.1 or something which isnt even an IP range in my network
it wont even resolve my router dns router.mydomain.net nor will it resolve any of my physical devices where the hostname is set in DHCP and it wont resolve any of my custom domains
and it affects every device on my network, windows machines, linux etc, as soon as I plug back in the WAN it will work again I dont even need to do an ipconfig /flush dns or renew or anything like that just repeat the nslookup and it works again!
So I just can't work out why it's doing this! the gateway and dns is set to my router ip so why should it matter I have no WAN the router should be handling the local hostnames inside my network without having to go outside to the WAN?
I dont have DNS Filtering turned on
Should I consider moving to something like pihole
LAN IP
Host name: router
DCHP Server
in WAN:
