dnsmasq on AC68U
squirrellydw
How can I add this to my router, I think I need to use dnsmasq and not sure how or if I can.
Router is AC68U with Merlin
thanks but confused in how and what I add? Also from reading that like it seems like hosts.postconf would be safer and easier but still confused in what I add. Any chance you or someone could give me a example based on what I have above?
You could use a postconf, but postconf files are scripts. So you would have to write a script to manipulate the file.
For what you want it would be easier to use a hosts.add file which just adds those lines of text onto the end of the existing hosts file.
For what you want it would be easier the use the hosts.add file which just adds those lines of text onto the end of the existing hosts file.
ok but how do I add/write this. I have no idea how to do it, could you help me out please.
Ok, I use a Mac usually but I think I have a PC laying around that I can use so I will try it when I get home. But all I need to do is
name it - hosts.add
and then add this??
IP NAME
