DomainVPNRouting Domain VPN Routing v3.2.5 ***Release***
@HKEPC,
Please open a separate thread to get help with your issue. I'll provide more instructions after you start the new thread.
You can ask how to use WireGuard Client's DNS exclusively in the new thread too. More people might join the separate thread.
Kindly,
How do i completely delete DomainVPN Routing from my AV86U_Pro router? Doing Uninstall from the AMTM menu still keeps the vz option in the AMTM menu, and the cron job is still in the cru list. I also tried using the uninstall command from the command line, but that had the same results. I rebooted the router after both but vz was still there.
I think there's a bug in the program's uninstall menu. It asks two questions. The first is whether you want to uninstall the program. The second is whether you want to keep the configuration. If you answer "NO" to the second question, the uninstallation doesn't occur. But if you answer "YES," the uninstallation does occur. Try it yourself.
Did you report this issue in the script's Issues GitHub page?
whahaha off course hahahaha... damn I think im to tired for today haha
1 192.168.100.1 (192.168.100.1) 2552.329 ms 3.407 ms 8.032 ms
2 10.80.0.1 (10.80.0.1) 11.739 ms 10.550 ms 10.418 ms
Yep.. domains use VPN haha
That's a built in feature no? LAN -> Route Tab
ehmmm,
im almost never login into the WebGui :) let mee dive into this
I don’t think this will help you for Domain VPN Routing, everything is driven by marking and ip rules.
Agreed, this scrip won't as it's purely Domain Name Based, but the baked in feature will since I had to use it a lot before you released this script. I had to IPvFoo a bunch of Domain names and route specific ip addresses over MAN (Man v WAN) didn't make a difference, both the same with Metric 0 and it worked fine. Everything else was over VPN anyway.
I am super appreciated of this script for what it does and time it has save me.
@poudenes Configuration as follows: IP ADDRESS 255.255.255.255 (for one single IP) GATEWAY (BLANK) METRIC 0 Interface as your need.
That's worked for me for ONE single ip address having to go outta WAN interface when VPN was active. YMMV so test away.
If anyone uses ASN, could you check if it's working for you? I'm seeing the following errors in my router log:
Oct 31 17:45:35 domain_vpn_routing: Query ASN - ***Error*** Attempt 1 failed to query ASN: AS62041
Oct 31 17:45:36 domain_vpn_routing: Query ASN - ***Error*** Attempt 2 failed to query ASN: AS62041
Oct 31 17:45:38 domain_vpn_routing: Query ASN - ***Error*** Attempt 3 failed to query ASN: AS62041
Oct 31 17:45:39 domain_vpn_routing: Query ASN - ***Error*** Attempt 4 failed to query ASN: AS62041
Oct 31 17:45:41 domain_vpn_routing: Query ASN - ***Error*** Attempt 5 failed to query ASN: AS62041
Oct 31 17:45:42 domain_vpn_routing: Query ASN - ***Error*** Attempt 6 failed to query ASN: AS62041
Oct 31 17:45:43 domain_vpn_routing: Query ASN - ***Error*** Attempt 7 failed to query ASN: AS62041
Oct 31 17:45:45 domain_vpn_routing: Query ASN - ***Error*** Attempt 8 failed to query ASN: AS62041
Oct 31 17:45:46 domain_vpn_routing: Query ASN - ***Error*** Attempt 9 failed to query ASN: AS62041
Oct 31 17:45:48 domain_vpn_routing: Query ASN - ***Error*** Attempt 10 failed to query ASN: AS62041
Oct 31 17:45:48 domain_vpn_routing: Query ASN - Processing Time: 29 seconds
When I try to check manually through the website https://bgpview.io/, I get the same error. I'd like to know: is this a website glitch or has my IP address been banned?
Use whatever tools you need to check the ASN. This checks whatever you need from a third-party address. You might be able to pinpoint the issue with proper tests.
But how can this be implemented in Domain VPN Routing?
The exact point behind my hint is that you can, with proper tests and verifications, rule out whether it's just you having issues accessing that ASN specifically, or it's a more widespread issue.
Hence, you can decide on proceeding to troubleshoot the script, or not!
Domain VPN Routing isn't working for me with any ASN right now. I'd like to know if this is because requests are coming from specific addresses. If the problem is with the bgpview.io service used by Domain VPN Routing, how can I replace it with something else?
Every ASN I check on https://bgpview.io/ results in an error. When I check an ASN on HackerTarget or MXToolbox they work fine.
