Don't work URL filtering
Boris8080
I have a router RT-ac66, last firmware. Tell me how to configure the url filtering certain addresses. I add this address in the filter, but nothing be happening
Disable HW acceleration, under LAN -> Switch Control. There's currently a bug preventing it from working with HW acceleration enabled, I believe I fixed it since the last release.
URL filtering is not working for me either - Asus RT-N66U on Melin 376.47
Do you have any advice how to enable it?
Yes, my advice is to read the answer I already gave in this thread, as this is the solution.
On my router I don't see HW Acceleration, unless I'm interpreting my settings wrong. Should I disable all of those options?
[/IMG]
As John says. I believe Asus renamed the option at some point.
Sent from my Nexus 4 using Tapatalk
In my case URL filtering is not working regardels if NAT Acceleration is disabled or enabled. :confused:
